04-19-2016, 11:05 AM
1989 sidekick, 2 door,4wd, 8v.
Just got this sidekick from my neighbor who blew the engine his first time wheeling it. Hydrolocked the engine, then threw the #1 connecting rod through the side of the block. My father and I just got done installing a salvage yard engine in fairly good shape. It would always run really erratic, even when the neighbor had it. Then yesterday I noticed an erratic clicking coming from the dash while messing around with it. It was almost like a relay click. Reached my arm under the dash and noticed that if I push up on the ecu connector then it suddenly runs good. I only had some old fuses around so I stuck the fuse blades under the plug to keep constant pressure on it. The car runs beautiful now. I guess my question is should I just leave the fuse/wedge in there? Are replacement pins for the plug available anywhere? Could the problem be in ecu itself? The plug looked good visually.
Thanks in advance.
Thanks in advance.
