  • 1 Vote(s) - 5 Average
ECU codes
Ok before going further I've decided to look for Ruby time bombs. My 47uf is dead and left some fecal matter behind. I have some caps at work so I'm going to take care of it. I will replace both 100uf and the 47uf should I be looking for any more problematic parts in the ECU? Also as a note on my 89 kick the ECU is layered on both sides but I'm 95%certain there is no center layers. If you look thru the board in front of a light no center traces are visible.
1989 Suzuki Sidekick 8V M/T (Full restoration project)
1994 Suzuki Sidekick 8V M/T (Full custom project)
1996 Geo Tracker 16V A/T (Runs but for parts)
Shocked
(06-12-2016, 01:00 AM)Freaky Beanie Wrote: Ok before going further I've decided to look for Ruby time bombs. My 47uf is dead and left some fecal matter behind. I have some caps at work so I'm going to take care of it. I will replace both 100uf and the 47uf should I be looking for any more problematic parts in the ECU? Also as a note on my 89 kick the ECU is layered on both sides but I'm 95%certain there is no center layers. If you look thru the board in front of a light no center traces are visible.
you are very wise, to do that.
1: 17mm snout bolt at 94ft/lbs
2: RUBY bombs. (more issues, nah , just them, bombs , the Black bombers.... im sure NSA will scan this...
3: dizzy 0-rings hard as diamonds, or near....
ive never xrayed the 60axx ecu's but the center layers may be sparse. if at all... 89s have NO spark(brains) so may e way less lay out there..?
how ever it does monitor spark carefully, (rpm /tacho) for injections, (that and engine load)
Do you know what's the purpose of Ruby 47uf? It was quite bad and ate a bit of the PCB and the trace.
sure.
all caps like this have but one purpose they are filters. (electrolytic, mostly) In electronic parlance it's "a bulk filter cap."
it's not optional at all, in fact nothing there is optional. (save, maybe one output port , ill not mention optional smog parts or ports....)(
That corner cap is the most key of all, and the most likely to fail. 1000s have.... now....
it filters out all those huge noise spikes the cars electrical system has. (capacitor oppose a change in voltage! and are why they are used for filters)
up to 100volt spikes, say from the a/c clutch going off line, and BAM. and other.
there are many inductive noise sources on cars, and is a problem (ask Ham radio operators mobiles) {relays, VSV , solenoids, injectors, ISC coils, and more.. even the starter solenoid)
if the cap is dead, the spike hits the regulator, and may do one of 2 things,
1: blow the REG CHIP up. Most IC's just hate 100v,spikes.
2: cause it to reset. and if IT resets, the CPU (processor ) resets, over and over, in most cases. The rubycons have all failed now.... seen only one that was good, in a ECU parked on self for 25 years.
of this era....
doing repairs under this cap , is not easy at all.
and depends on level of damage
here are some levels
just green slime there, clean it with bicarb, and put in new cap, ready to rock.
green stat too long trace damage top, ok , bicarb it , and fix traces , new cap, done.
then the green gets deep, way deap and wrecks both sides, can be fixed,sometimes.
and last it burns up. the cap shorts, the green causes the PCB to burn. helps it. and is mostly hopeless.
damage has no limits. and many parts on this PCB are not sold anywhere.
best is to always have 1 spare ECU, they wont get easier to find, nor fix at all in the future.
if lucky you can find a used one for 50 bucks, most places have scalping prices. like $500
find a person selling. one that is just regular person, (on fleabay 9 of 10 are the scalpers. it's there prime territory there) the price is the key clue.
Ohh so it's input not output. Glad to be protecting my ecu then. Ohh and my model if 89 is manufactured in 04/89 Japan. Wink
And the ECU had minor damage to the trace. Cleaned it and made the trace again out of solder.
(06-17-2016, 02:26 AM)fixkick Wrote: sure.
of this era....
the cap is located on the 12 to 15vdc battery power input mains, called IG-coil fuse ,
This is called, IGNITION power in the generic jargon.
that is an INPUT, power is INPUT To the ECU and runs (powers) all regulators on the ECU, the ECU runs off 5vdc not 12vdc so all ECUs have a regulator to achieve this, need.
the cap filters out all noise and damaging spikes to said regulators.
if not, the blow up.
most the regulators are not sold now, so you never want to blow one up.
a nice cap , seen on my caps page, does just that. from japan, not china with no "top brand" name on it.
yes, all first made 89s were made in JAPAN about April 89 the production shifted to CAMI. in Canada. when as did many parts, too. including cami made HVAC, system.
i THINK yours will run a long time, lacking the deep damage seen on so many.
