1999 jeep wranger automatic with 4.0
Engine cranks over fine but no fire it just dyed on me . There are no codes and when checking for grounds and voltage at the test port under dish there is voltage and ground but no can buss no resistance reading on high or low buss.
i have 95/ 2008 and sold a 2002 wrangler ( this a huge mistake the 02)
The PCM on this car has an ASD relay. that drops of any of 6 errors happen. ( lost spark,cmp or CMP dead,injector shorts, 02 sensors short,)
First is check all fuses. not blown.
No real scan tool? OBD2?
then check for spark the classic way test. got spark is first, if the PCM sees spark bad, it cuts fuel so FUEL IS ALWAYS last test.
what is the BUSS thing? (can bus?)
this is a 1999 TJ wrangler, I assume USA car, not canada. etc.
I your Full shop manual FSM in hand ,PDF opened now, on my screen.
the 16pin scan tool port at right lower knee, Pin 16 must be at 12vdc for sure key on, of the scan tool going to fail. (only cause is fuse blow to it)
next up if the super secret dash warning lamp for SECURITY key, it is only a RED LED with NO words OR icons AT ALL. STEALTHY,
THIS led MUST NOT GLOW AT THE TIME YOU CRANK THE STARTER. OR ALL SPARK ENDS BY DESIGN (MEANS FUEL TOO)
THE SCAN TOOL MUST SUPPORT obd2 PORT PINS 3 AND 11, jEEPS ccd BUS IT IS.
PIN 7 IS SCI COMMS the scan tool must at least support pin 7.ISO 9141 aka, K-line
Pin 16 dead is fuse 20 blown in PDC fuse box. 10amp fuse.this fuse is hot full time, keyoff too. 12 to 15vdc not less. for sure never less than 10vdc or all; computers in the car go (dump/mad/offline)
the test is use the scan too like this,
its connected and on.
KEY on engine off the too talks to the PCM and shows EPA smog monitor pages, status fully, complete or not complet monitors if not tool bad/wrong tool or fuse blown
with the scan too working
key on,
crank for 5 full seconds
then release the key not off
scan the PCM now.
see DTC p03xx and bingo.
the rule on a dead jeep is, the crank must have turned 10 full spins, turns, to set the error.
5 seconds it does that.
sorry so late.
Merry Christmas eve to you and all. !!!!
