01-31-2020, 05:56 AM
When replacing the clutch, I will also replace the pilot bearing (since a clutch kit includes one) - this pilot bearing is in the flywheel
- you mentioned inspecting the tranny pilot shaft bearing and seal - this is a different bearing, correct?
I was going to get this clutch kit from RockAuto:
https://www.rockauto.com/en/moreinfo.php...&jsn=12187
Then this would be the tranny pilot shaft bearing you suggested I replace?
https://www.rockauto.com/en/moreinfo.php...&jsn=12156
And the seal?
https://www.rockauto.com/en/moreinfo.php...&jsn=12159
Going to order all these soon (in addition to the order from megazip i mnetioned earlier)
Cheers
And the seal?
Cheers
