1998 Tracker, 16v, 3spd Stalling and Stumbing rears it's ugly head again.
I THINK WE ARE ON TO SOMETHING!!
Look at the fuel piss out of the vac nipple!!!!!!!!!!!!!!!
13 second video >>>HERE<<< (streamable, new to me and very impressive at quick video uploads with no account requirements/ads)
I wish I had have pulled off the FPR vac hose back in December...
Anyway, I have a good running 97' I can pull the FPR off, but likeyou mentioned its old and failures are likely. Is there a preferred aftermarket part anyone can recommend to replace it?
(04-30-2017, 09:07 PM)Perry Wrote: I wish I had have pulled off the FPR vac hose back in December...
seem like all G16b engines are all doing this now;
its at the end of there life.
all that fixes, every time your toe (right) moves so does it,
end of life
we check fuel pressure first, when engine runs rich, and sensors scan ok (o2 will read wrong but its not 02, its only reporting TRUTH here)
the ECU is helpless to see pressure wrong, (un like new cars)
Some FPR are far worse, they stick inside, while driving, only a remote fuel pressure gauge finds this, driving..
that is way some just replace it and guess, due to the hard nature of failures... possible.
some get this grove inside that causes jamming, randomly.. sux too... that...
glad you found a leaker. cracked diaphragm
(04-30-2017, 09:43 PM)fixkick Wrote: seem like all G16b engines are all doing this now;
end of life
I know the Suzuki dealer here is going to want a small fortune for this, and I know the one on my 97 is probably good but I want piece of mind. Do you have a recommendation? I was thinking about getting this one. Has 5 year/50,000 warranty so that can't be a bad sign.
i think every AUTO store in usa sells this.
SMP is a #1 top maker here, of aftermarket parts, huge sales. great stock to own .
aka BWD , in Canada.
rockauto does, and shows them all,
and all brick stores
id just google the SMP part number if price shopping
or check you local stores.
be sure to get year right some dont have the dog leg older G16s.
$187 at one suzuki dealer.
wow the beck is on sale. a top maker too.
Today I took the FPR off the 97 parts vehicle i have, and NOW IT RUNS PERFECT!!!! Still waiting on it to complete the egr and catalyst monitors but it will now idle at 800 hot all day long. Thanks for your help fixkick! You're the man!
(05-02-2017, 05:42 AM)Perry Wrote: Today I took the FPR off the 97 parts vehicle i have, and NOW IT RUNS PERFECT!!!! Still waiting on it to complete the egr and catalyst monitors but it will now idle at 800 hot all day long. Thanks for your help fixkick! You're the man!
WOW AND FREE FIX TOO....
glad to help !
cheers,
You think that alcohol in the fuel may have something to do with all the fuel pressure regulator failures?
(05-03-2017, 12:07 AM)fetcher Wrote: You think that alcohol in the fuel may have something to do with all the fuel pressure regulator failures?
it may
but 10% should be ok.
