02-22-2018, 02:40 AM
89 tracker 4x4 Have been fighting coughing erratic throttle,took it to work on in my Sons garage yesterday .While opening garage door I then returned to pull it in and it had died. Wont hit a lick, getting fuel but no spark, checked fuses,resistence at coil, I'm getting a code 12, guess ill pull ecm for bad ground or whatever. any other suggestions? recent timing belt,crank pully cked and torqued. Previous owner hacked the ignition and replaced ignition switch with toggle and push button start. never had issue in 3 years iv owned it. I kinda like it cause I can let it warm up in the Midwest winter and lock the steering column. Had been fighting high idle issue also, cleaned throttle body,w/new gaskets of corse, new vacuum lines. cal. TBS , checked and cleaned EGR. The hits just keep on coming.
