1.6 8v TBI - TPS rich Misfire - Need help.
The map sensor seems to be working appropriately and gets good vacuum from the manifold. The filter on it also allows air to pass both ways freely.
Well I found what my problem was. I found a flipflopped TPS wire under my dash where I could not see it. Whoever did this swap crossed the Gray and Yellow TPS wire with the Green and Yellow egr solenoid. Once I flipped those and connected everything she started running perfectly without misfires at all.
Huge change in power and performance. My timing advance came back as well.
Thanks for the help....
