03-31-2018, 08:28 AM
Aloha,
My 89 tracker was made in Japan. I'm having a beast of a time figuring out the surging idle. I tested my TPS it seems to be good. I put the jumper wire in the clip so I could get a code read out and the check engine light just stays on. My fuse box has a Diagnostics fuse. I've tried this with and without both.
The EGR is like over $200 and then there's the unit right above it that helps it. The EGR seems to work the diaphragm goes in and out when I suck on it I don't have a vacuum tool.
If anybody can help me figure out how to get the codes plus any Source where I might be able to buy parts. It's got a hundred and twenty thousand miles on it and it's been pretty baby. So I really want to get it running good all the chassis and moving parts are all solid.
Mahalo for your help
