1992 sidekick jx 1.6 16v needs yoke
not sure what else I need.
Victoria
Hello old friend from 2007 !
nice to see you are still sidekick active.
you need the front end of rear driveshaft yoke to tranny? part?
what tranny 3/4;5 speed? and what is door count.
knowing that i can cross them to all years. and options,
making it easier to find it.
suzuki sells it but will be $$$ they seem to be doubling prices every 3 years. and are chapter 11 , in usa and closing in Canada.
their parts window is open. still
one place to find parts is car-parts.com
they have old parts. its a networked wrecking yard system.
the problem is most want to sell the whole dive shaft, as the yoke is fixed to the u-joint and they dont like to remove it.
but calling them might get better answer, (they have a bend shaft and they say yes?)
the shipping can be steep, but usps express, has flat rate if it fits in box.
ill look up the pn and variance and post back
cheers to you
suzuki rear drive shift front yoke.
all 4wd, no 2wd
1989- to 1995 (96+ splines changed, cant use it)
use
#27140-60a00
suz, is $142 buck, not cheap
http://www.oemsuzukiparts.com/parts/inde...eid=214330
suz used parts are not all that easy to find in uSA, and worse in the south., besides , places listed car-parts.com
but in canada they are swimming in them.
up there they rust though and the MOT inspector, jerks the registration, (condemned) so parts are every where. in canada.
how to find them i, i dont know from here.
i have an 2004 GV and bent my yoke, and had to buy it new. last year, so know how hard it can be.
good luck to you .
it will move in 4wd And sits in 2wd.
tthis one has had almost every part replaced. I will look on carpets.com and am hoping that I can get my brother to do labor.
i see your 2 photos.
is the 2 problems ?
right front axle.?
and a drive shaft failure?
4wd but what transmission? you have.? 3/4/5 speed.?
ok the front drive yoke has the same part number s the rear drive shaft yoke, (makes finding it more easy 89-95')
that damage looks like missing snap ring, results. or horrid wide up, on pavement.
is axle pig full of oil. which end failed front of car or rear drive shaft)
can you turn rear wheels by hand axle off ground ,turn 1 other goes backwards.?
then (carefully wheels chocked up front, xft case in neutral, drop one rear tire to ground , and spin the other by hand , see the rear axle pinon now turns?, smoothly.
(no brakes set, thus flat ground, and chokes set)
the front end, of car, if that end failed??? , we need to check that end too.
this is not normal, need to look at things.
not driving on pavement in 4wd ,right?
make sure both pigs (axle 3rd members, or gear sets are full of GL- 5 lube) level to axle fill hole ,bottom edge.
usually 95HP cant do this.
92 is driveshaft failure the 2wd doesn't work. vehicle is.4 door. sent you picture of shifter picturew o/d automatic on the fly no lock outs on this one. 92
is part number still the same you just posted?
just showed my brother part broken and told him you was going to let me know part number. he's going to try and help me get it fixed.
I need the info on how to replace the oil pan basket also. I never got that done.
thanks
Victoria
trying to locate the new post button for the 94 axle issue so I don't get them mixed up new thread.
still not found where I need to be. sometimes this smart phone is a.pain.
(10-14-2013, 06:25 AM)star2525 Wrote: 92 is driveshaft failure the 2wd doesn't work. vehicle is.4 door. sent you picture of shifter picturew o/d automatic on the fly no lock outs on this one. 92
is part number still the same you just posted? YES
thanks
Victoria
yes, that p/n i posted , fits both the front drive shaft and rear, (suz calls them propeller shafts connect to transfer case , front and rear.
#27140-60a00 (prop shaft yoke) (fits both)
pan gasket is a horror.
engine out. or drop front axle and do .
here is the drop way, huge job ,see photos
http://www.fixkick.com/axles/Pan-drop/pandrop.html
(10-14-2013, 07:29 AM)star2525 Wrote: trying to locate the new post button for the 94 axle issue so I don't get them mixed up new thread.
you got it ok, you have 2 posts, 2 cars. all is good.
and good luck to you.
you are great as always!
here is why pan will not come off
tight fit to axle , seen clearly below. no transmission.
so 3 ways, pull motor, pull axle, or pull tranny and flywheel and then a cussing job on your back.
Id pull engine, if have engine puller. Working on you back is no fun.
in fact inverting the engine works best,the factory pan is glued on, with RTV, (blue or orange code) the Felpro kit has cork gasket making it easier.
cant use gasket 96+
[Image: clutch1a2w2.JPG]
if you need help, just holler.
glad to help.
