Hello and Tracker belt replacement questions
Hi all, I got a 1995 16v 2dr 5spd 4wd Tracker, now the wrenching begins! The Tracker runs and drives but came with un-installed brake parts, alternator, belts, and u-joints. I want to at least get all these parts installed before driving much. I have done some work on motorcycles but not a lot on autos, so please excuse my ignorance.
The truck was sold at 20,000 miles to an RV person who towed it around until ~160,000 miles. It now has 170,000 miles. The latest owner drove it locally.
Timing belt
Is this belt tensioner correct? Also is there a spacer missing on the adjuster quadrant stud?
The timing belt looks "OK". It is a Dayco brand, but the new looking alternator and steering pump belts are both NAPA and look newer. There is no date written on the belt cover. My best guess is the timing belt has been replaced once, but probably not twice.
Other comments on what I have found
- Removing the skid plate, upper radiator hose, and jacking up the front end made it possible to do this work Smile
- I could not remove all the tension on the power steering belt. The sheave hub hit the mounting bracket. I got the belt off but is this right? It has the correct belt.
- My new  alternator is clocked a little bit differently than the old one. I think the battery wire will reach.
- The steering fluid is very low and there is some seepage/oily dirt around the pump (no obvious leak or drip). There is a bit of end play in the pump, maybe 0.050". I have OCD and figure I ought to go ahead and rebuild the pump. Any reason to think it will last a long time if I don't?
(02-01-2021, 11:39 AM)dhally Wrote: Hi all, I got a 1995 16v 2dr 5spd 4wd Tracker, now the wrenching begins!
Timing belt
Thanks for posting and sharing.
me to learned on motorcycles,  and the tracker is just 4wheeled motorcycle. with a cage. LOL
160k miles towed with rear tires on the ground,, the rear bearing of the 4wd transfer case may be a wreck. (run dry doing that  act) if was.
tensionor looks correct, but that spring only used at 1 strep in the install process and then locked down with stud seen there. for 60k more miles.
but the washer is missing.  factory drawing is in my page 15v tbelt.
PS is tricky, the bolt for the mount is hidden deep via, putting wrench inside the pulley front hole (window)
the belt may be wrong, sized.
very common folks using wrong belt here.(P/S) for without out A/C the belt is short. but not too short.
DAYCO #5040323DR  (some are ~320DR), no AC
there 5 belt sizes sold for this one year car,. yeah, (engine/body/ac or not)
14mm wide, and 814mm circum  32.09" inches. say Dayco.(no A/C)
tricky this belt is, 2 engines , 2 bodies) and with and with out AC , lots of bets in the parts list for this one car 92-95 (Suzuki real parts list)
4door and 16v is unique.  and 1995 has its own belt and all had AC then. making parts buys hard if 1995 is missing the AC.
NO A;C
P/n 1995, 16v only is. suzuki book, 17521-60A00 (suz  #) = DAYCO 5040320DR
Ac has 5 different belts. so I  will skip all those.
Dayco is High Q brand and is. last long as does GATES.
make sure to use the correct lube fluid in the P/S pump or it will not be happy. DEXRON III or higher.  use highest numbers sold today.
your free users manual is here.
Alternator clocked wrong , but sure wrong alt.
but do know that this car does not have ECU controled Alternator. (the regulator is inside ALT and not inside ECU)
it is very simple,  can even run by itself on a tall pole + fan blade as a power generator. said to show how easy and great it is, and easy to make work.
but on some brands of alt sold the idiot lamp below must be good. or Alternator does not Self Excitation 1.  (if residual magnetism is gone)
just 4 wires, counting ground
[Image: charge89.jpg]
