New Owner
There was a bad spot on the bolt threads and the hole (about 2 threads worth), don’t know what caused it. Looks like it will clean up pretty easily with a 12mm x 1.25 thread chaser.
Having difficulty finding the bottom cog. Only place so far is an eBay listing from the Middle East. Still looking...
Found the cog (12631-53B00) on Suzukiautomotiveparts.com for $46 shipping included. 17mm bolt is $11. No woodruff key listed on this site, may find elsewhere.
Fixkick
Camshaft timing belt cog removed, locating pin and corresponding slot on cog look perfect. However, I do want to replace the bolt. Do you have a part number? Can’t find it.
Again, thanks for the help.
(07-16-2020, 06:08 AM)Nonmilagno Wrote: Fixkick
sure
on my cog wrecked page see the p/n table  bottom of page here.
https://fixkick.com/t-belt/damage/index.html
12619-53B01
92 up, 16valve.
if any dealer has B02 up that means newer revision, no fear. that.
Searched that number, isn’t that the crankshaft bolt? I need the camshaft bolt.
(07-16-2020, 07:40 AM)Nonmilagno Wrote: Searched that number, isn’t that the crankshaft bolt? I need the camshaft bolt.
sorry my bad
will send number in AM, early
Thanks a lot, I really appreciate the help.
(07-16-2020, 11:42 AM)Nonmilagno Wrote: Thanks a lot, I really appreciate the help.
there are 4 engines, 89-98?
not sure which you have,
G16 is the guess. and can be 8valve or 16v head,  but seems to be same on all G16
1991 and up.
 cam bolt is 01550-12253  (my EPC clearly states, this) cam sprocket bolt.  even used on 2003 Grandvitara G16b( 16v) and Esteem G16 too.99-02)
suz says superseded by.? IDK
01550-1225A
the drawings at suzuki skip this bolt, not seen at all in the drawing there. adding to the drama.
https://www.amazon.com/Suzuki-Bolt-01550...B01LZXDNO0
even suzuki gets confused here
https://www.suzukiautomotiveparts.com/oe...015501225a
Thanks for the numbers, I’ll check it out.
(07-16-2020, 11:15 PM)Nonmilagno Wrote: Thanks for the numbers, I’ll check it out.
you are very welcome and anytime, please ask.
PS good luck on your build !!
