Flat towing w/ auto hubs
Hello, from Westport WA.
I'm new here and really appreciate all the info this forum and site has. Thank you fixkick!
My recently acquired '93 Sidekick 4-door 1.6 16v 5-speed manual w/ auto hubs is going to be towed to Baja Sur in a couple months behind my friends truck. It's a four long days of driving.
My question is: Can I flat tow this vehicle with this set-up or do I need manual locking hubs? The google searches are inconclusive.
Thanks!
(02-06-2020, 09:19 AM)Baja_bound Wrote: Hello, from Westport WA.
Thanks!
well for sure we don't want to wreck the bearing #43 in the tail shaft of the transfer box.
Your car is method A or C
https://fixkick.com/FAQ/FAQ.HTML
method C is backwards towed, so it's "A " i'm sure.
or drop the rear  ENd of rear tail drive propeller shaft (4 bolts/nuts) and bailing wire it up, top. and tow it any distance and no damage ever.
also old cars like this, make sure the auto locking hubs in front are not SEIZED.  jack each front corner of car tire off ground, make sure when you spin the tire, the behind axles do not spin, or the hubs are shot.  or tow car with them removed..   (the manual states tow car backwards on dolly,  id remove the hubs.AUTO, or up grade to WARN manual hubs.
shows all ways possible. here. all 4 ways #4 is suzuki way. #1 is drop prop shaft rear.
https://fixkick.com/tranny/xfr-case/transfer-case.html
the operators guide is here. 95, chapter 8 is towing.
https://geo.pink/download/95]
[url=https://geo.pink/download/95][/url]
GReat! thanks for all the info. I didn't realize (but should've known) you had that in faq's. I will probably swap out the auto hubs for manual after reading all of that and looking at the exploded views of the auto hub and the unknown history of this vehicle.
Having some serious second gear hesitations now but I'm reading up on that here and trying the all the recommendations before I ask questions in a new thread. want to get it running smoothish before 60k tune up but chicken/egg scenario. current miles are 71k no receipts or maintenance history so assuming not done
