A/C leaking at the compressor manifold - Printable Version +- Car Repair Forum (https://fixkick.com/forum) +-- Forum: Suzuki (https://fixkick.com/forum/forum-suzuki) +--- Forum: Sidekick/Tracker (https://fixkick.com/forum/forum-sidekick-tracker) +--- Thread: A/C leaking at the compressor manifold (/thread-a-c-leaking-at-the-compressor-manifold) |
A/C leaking at the compressor manifold - Azplinker - 05-25-2016 Put U/V dye in and it appears that my freon leak is between where the hoses attach to the top of manifold (3) and the manifold to the compressor (2). Do you have any information about the size of the O-rings inside the manifold and especially the rectangular O-ring (6)between the two pieces of the manifold? P/Ns? RE: A/C leaking at the compressor manifold - fixkick - 05-25-2016 suz p/n 3=95254-82000 5=95259-82001 https://www.suzukicarparts.com/parts/1995/Suzuki/Sidekick/JS/index.cfm?siteid=214820 both are listed here shows no size, sadly hope that helps |
