Cracked 1.6l block at 3 to 4 crank web - Printable Version +- Car Repair Forum (https://fixkick.com/forum) +-- Forum: Suzuki (https://fixkick.com/forum/forum-suzuki) +--- Forum: Sidekick/Tracker (https://fixkick.com/forum/forum-sidekick-tracker) +--- Thread: Cracked 1.6l block at 3 to 4 crank web (/thread-cracked-1-6l-block-at-3-to-4-crank-web) |
Cracked 1.6l block at 3 to 4 crank web - tuckev - 05-05-2016 Found another cracked 1.6l block. Have seen several of these. Crank web is cracked starting at the main bearing and goes all the way up between the #3 and #4 iron cyclinder liners. I have seen the crack go all the way up to the cylinder head surface. Always between #3 and #4. Anyone in the Tucson area have a spare 1.6l block (hopefully uncracked)? RE: Cracked 1.6l block at 3 to 4 crank web - fixkick - 05-05-2016 all from running water for coolant, every one, some just don't want to believe water expands, when if freezes its the force that crack mountains in 1/2 for eon..... one of the biggest natural forces on earth. besides quakes. sad to see, no? nice engine wrecked for $8 of coolant... |
