1995 tracker clutch pedal pivot bushing - Printable Version +- Car Repair Forum (https://fixkick.com/forum) +-- Forum: Suzuki (https://fixkick.com/forum/forum-suzuki) +--- Forum: Sidekick/Tracker (https://fixkick.com/forum/forum-sidekick-tracker) +--- Thread: 1995 tracker clutch pedal pivot bushing (/thread-1995-tracker-clutch-pedal-pivot-bushing) |
1995 tracker clutch pedal pivot bushing - sloshua - 04-29-2016 Hello need help with part number for the clutch pedal pivot bushing. Replaced the cable today and seen the pivot bushings are all knackered. Used to be able to find this part on ebay but now it seems to be unobtanium. RE: 1995 tracker clutch pedal pivot bushing - fixkick - 04-29-2016 its a dealer only part , if seen on ebay its used or someones excess stock or from a chapter 11 closed suzuki dealer, (lots did. ) where is it , in the pedal mount bracket? the drawing for 5speed, no cruise is one page see here for $5 , takes 2. for clutch only not brake shaft. 09307-16001 https://www.suzukicarparts.com/parts/1995/Suzuki/Sidekick/JS/index.cfm?siteid=214820 RE: 1995 tracker clutch pedal pivot bushing - sloshua - 04-29-2016 yes its the 2 bushings in the pedal mount bracket that the clutch pedal pivots on. Thank you! wow 14.99 for shipping
