Need Fitting That Oil Filter Screws Onto - Printable Version +- Car Repair Forum (https://fixkick.com/forum) +-- Forum: Suzuki (https://fixkick.com/forum/forum-suzuki) +--- Forum: Sidekick/Tracker (https://fixkick.com/forum/forum-sidekick-tracker) +--- Thread: Need Fitting That Oil Filter Screws Onto (/thread-need-fitting-that-oil-filter-screws-onto) |
Need Fitting That Oil Filter Screws Onto - jimlindenfelser - 04-26-2016 See pic. I dont believe I removed this when I had taken engine apart to have machined so maybe the machine shop did. I do believe I may have seen this among the rebuild parts they gave me but did not know what it was. I could probably get one from my local pull and save. They have some Suzuki Swifts which I believe used the same block. What is it called and is there a source for buying one? Have not tried dealer. RE: Need Fitting That Oil Filter Screws Onto - fixkick - 04-26-2016 when you unscrew the filter this can fall out and stick inside the filter, find filter, find, it. it has a number at suzuki that i have , and fits other suzuki stand, oil filter name 11241-73003 fits 121 engines in the db, fits so many i cant count the SA-310 SE,SA,SD,SF,SQ,SJ, SK $10 https://www.suzukicarparts.com/parts/1995/Suzuki/Sidekick/JLX/index.cfm?siteid=214820 id not think generic auto stores sell this... id loctite it back. RE: Need Fitting That Oil Filter Screws Onto - jimlindenfelser - 04-27-2016 Thanks! I was all set to get ready to turn engine over to check engine pressure and flow to the head when I notice this missing when I went to screw on fiilter RE: Need Fitting That Oil Filter Screws Onto - fixkick - 04-27-2016 me too, many shops lose it, and for sure if pressure tanked cleaned, lots pressure and vibation can be in bottom of their clean system tank. sorry it happened to you, what a let down , on "fire works day" RE: Need Fitting That Oil Filter Screws Onto - jimlindenfelser - 05-03-2016 Well oil filter stand was on back order according to the suzuki dealer. Ended up getting a couple from the local pull and save out of a couple geo metros. Turned engine over and have pressure and oil flow to the head. Time to button everything up and double check all my wire splices. Thanks for the help. RE: Need Fitting That Oil Filter Screws Onto - fixkick - 05-03-2016 metros save the day , hoo hoo RE: Need Fitting That Oil Filter Screws Onto - jimlindenfelser - 06-16-2016 I want to thank you for your help with all my questions and for all the info on your website. My rebuilt 16v started right up in my samurai! I now have 200 miles on it. RE: Need Fitting That Oil Filter Screws Onto - fixkick - 06-16-2016 what a nice job. looks really good. 95HP in sammi,,, wow... |
