92 Tracker won't start - Printable Version +- Car Repair Forum (https://fixkick.com/forum) +-- Forum: Suzuki (https://fixkick.com/forum/forum-suzuki) +--- Forum: Sidekick/Tracker (https://fixkick.com/forum/forum-sidekick-tracker) +--- Thread: 92 Tracker won't start (/thread-92-tracker-won-t-start) |
92 Tracker won't start - Fifthfreedom - 02-10-2016 I have a 92 Tracker 5 spd 4wd. I bought it a few months ago. I've replaced the battery and alternator. When I turn the key to ON, the dash lights are on. Fuel pump primes. Turn it to Start and lights go dim, might try to turn over, might not. Will start with a jump but runs rough. Each gear shifts fine but throttle after sputters. I'm out of ideas. Any help is appreciated and thanks in advance. RE: 92 Tracker won't start - fixkick - 02-10-2016 welcome Fifth. looks like many problems, but lets fix #1 first. the gross power loss from battery see the green here http://www.fixkick.com/electrical-failure.html see the schematic there too>? that is all you need and a meter to find cause. of starter and gross elect.[/color] power failure. (02-10-2016, 07:49 AM)Fifthfreedom Wrote: I have a 92 Tracker 5 spd 4wd. I bought it a few months ago. misfire has 50 causes. but tuneup skipped tops list... |
