1990 Geo Tracker 4x4 Manual ECU 60A31 Repair - Printable Version
+--- Thread: 1990 Geo Tracker 4x4 Manual ECU 60A31 Repair (/thread-1990-geo-tracker-4x4-manual-ecu-60a31-repair)
Pages: 1 2 3
RE: 1990 Geo Tracker 4x4 Manual ECU 60A31 Repair - fixkick - 11-08-2016
caps
yes the Rubicon caps fail, all do. (did) i saw one that did not. a new one sitting in new box, on the shelf for 20 year.
they just dry outside,
the fails the capacitance test, and ESR test, hard failures
that corner large cap , bad,will cause the ECU processor to reboot over and over, as the 5v regulator drops out. The cap there must be good.
and yes, the ugly ones, with acid damage are obvious, but not all do that, some just dry put, or split the case on the cap.
60A91 CAN-MT
60a is early side kick ECU , , the A ,ecu is no spark ecu, ecu creates no spark only fuels engine.
Can -= for Canada smog regs. (ours is US marked) or CA for California.
MT is manual trans.
are you in Canada?, im in texas
(11-08-2016, 01:35 PM)Jake 1 Wrote: OhYa! The whole hot wire thing....I doubt 12v of any kind thru either injector lead would work for too long...You know ..the 100w light bulb thing comes into play. My safety in the outback at this point is a handy wrapped ecu!! LOL.
yes, the 100 watts of heat alone can burn up the circuit board if it land on large resistor.
I use the 100 bulb thing cause most folks burned a finger on one, and can imagine 100watts of heat on rice sized chip. will get even hotter.
RE: 1990 Geo Tracker 4x4 Manual ECU 60A31 Repair - Jake 1 - 11-09-2016
yup
i'm a canuck....near Vancouve bc
RE: 1990 Geo Tracker 4x4 Manual ECU 60A31 Repair - fixkick - 11-09-2016
[quote='Jake 1' pid='7293' dateline='1478634599']
yup
[/quote
Great and welcome !!!
