Sidekick engines tilt on driver side ? - Printable Version +- Car Repair Forum (https://fixkick.com/forum) +-- Forum: Suzuki (https://fixkick.com/forum/forum-suzuki) +--- Forum: Sidekick/Tracker (https://fixkick.com/forum/forum-sidekick-tracker) +--- Thread: Sidekick engines tilt on driver side ? (/thread-sidekick-engines-tilt-on-driver-side) Pages:
Sidekick engines tilt on driver side ? - john110 - 01-11-2016 is it the case, I think the engine is incline some degrees by the driver side. is it the case, what`s the % and the reason. Someone in my area who like and rebuilt some Trackick told me(2 years ago) that it was for better oïl drainning. I never got any answer about this, if someone can answer this it has to be you Kick!! I`m talking about 94/95 generation..... RE: Sidekick engines tilt on driver side ? 8v? - fixkick - 01-11-2016 the 8v or 16v the 16v tilts front to rear only not side to side. if you look at vast photos 16v the plenun top is flat left to right the 8v? the heads have many oil drains, no needed for tilt to drain right, ever. but the 8v looks like this example. it does seem so but? is it? http://www.fixkick.com/t-belt/t-belt2w.jpg http://www.fixkick.com/t-belt/donebelt1.jpg the belt cover show huge tilt not sure its really tilted or and illusion.? ![]() here is my guess)if they all tilt for normal torque reaction when you accelerate hard, the engine jumps to . drivers right, from , where it was... if is tilted, (if) so that means it dont hit things on others side. call it a flex zone. which allows a larger intake manifold that side, and larger plenum ,ALL EFI loves. here is my 97 16v no tilt or small http://www.fixkick.com/engine/97-motor-pull/HTML/image_58.html what engine to you have and got photos of tilt? RE: Sidekick engines tilt on driver side ? - john110 - 01-11-2016 It`s a 94 1.6 8v. Looking at your pics it seems to be inclined on the driver side. When I did my engine swap last year I was wondering if I replaced correctly the two rubber parts on witch sit the engine. But when looking at many pics , we can see that the engine is slightly inclined by the driver side. Even when looking at the cam bolt, it`s not vertical(90 degree) with the crank bolt. RE: Sidekick engines tilt on driver side ? - fixkick - 01-11-2016 any tilt there is for torque reaction take car with a/t trans put in low all brakes hard set hood up , car point in clear safe direction observer to left side of engine bay. driver floors the throttle. see that engine move, now. . lots of movement. (called the stall test in FSM , a/t chapters) and needs room to do this, and many engines are pre tilted to make parts fit better over there or lower hood lines or have huge intake manifold or all those. but a V engine this hopeless.but many inline engines have natural tilt, from a little to huge seen a Plymouth slant 6? http://www.allpar.com/photos/mopar/images/1961-Aluminum-225-slant-six.jpg for sure hood lines tops list many sports cars with a huge inline engines,tilt. this engine is used,in other cars too. the cams bearings drain, with no problem , you can park anywhere and they drain perfectly even in san francisco. (shocking tilts) i wish now my tripod had my spirit level attached. ![]() engine block pan off , crank out and sitting on a bench. no tilt head on, no tilt or offsets but in car mounts dictate this what matters is when the engine flexs to the right, it dont hit things. it does move. the right mount compresses and left stretches. RE: Sidekick engines tilt on driver side ? - john110 - 01-11-2016 "here is my guess),,," ok I didn`t saw that part when first reading. and it makes a lot of sence.......... RE: Sidekick engines tilt on driver side ? - fixkick - 01-11-2016 here is the block, upside down 8v or16 use same block http://www.fixkick.com/engine/97-motor-pull/HTML/image_27.html no tilt, there is the illusion of some, but its just , odd shapes...tricking the eye. the 16v cam sits to drivers right in head, but that is an offset, not tilt .its all in the ,mounts on the esteem G16 they'd want lots of tilt for low hood line. im sure they did. .? RE: Sidekick engines tilt on driver side ? - john110 - 01-11-2016 That`s weird the cam cover isn`t bent but on 8v engine ist`s inclined. so are those mount meant to get the engine inclined ?! RE: Sidekick engines tilt on driver side ? - fixkick - 01-11-2016 i thiink all engines are inclined front is top from to back is inclinded left to right is tilt or offsets. the incline is to slowly work the crank to trans LEVELS, bit by bit DROPPING to the level of the off set, rear axles pinion (HYPOID GEARS THERE ARE OFF SET TO TOP FOR SAME REASON) and to keep u-joint not angled. (or the go bad fast) READ up on how to match driveline parts of ... any title is in the mounts. all mounts the block for sure has no tilts. see my photo of block sitting flat on 4x4's zero tilts. of any kinds. the whole engine inclines from crank tip to rear axle, for really good reasons. the 5sp in 4th gear is straight shot true the main shaft, no inclines possible there.. nor in the transfer case it does same trick in ITS main shaft. so all angles now are poor u-joints, so they incline the engine to solve that serious problem. the 4wd has a problem too the front axle pig, 3rd member is just below the pan so dropping the engine is not possible but tilting is. see? the look at the fixed rear axle pinion, and do drop to there. now all this makes sense,no? RE: Sidekick engines tilt on driver side ? - john110 - 01-11-2016 "any title is in the mounts. all mounts the block for sure has no tilts." That is what I was thinking..... engine sit on the floor is strait up, cam cover is equal both side..... and when looking at about all 8v pics in those little car/trucks the valve cover is tilted by driver side..... I`m wondering if metal frame mount are leveled or if it`s the rubber parts that make it that way ? http://www.fixkick.com/t-belt/t-belt2w.jpg Kick, do I need new glasses or the cam pulley is on right side of the crank pulley ? Btw, I really don`t want to be tiresome with that sujet but it`s the first time I got serious answer about it. RE: Sidekick engines tilt on driver side ? - fixkick - 01-11-2016 first off you are welcome here,and to ask anything, all to happy to help you, !!!! im 3000 miles from home, below the equator, fun in the sun.... and have no access to my thousand photos, oops , i FTP'd to my server, found more. that photo above lacks a reference point. is engine tilted or is my camera. the cam is dead center of the 8v head, but not the 16v (16 IS OFF SET) how about this view and the pan interference. http://www.fixkick.com/engine/myclutch/clutch-locked.jpg or this,, look tilted, Left to right (front to rear incline happens only with transmission connected. ![]() show a photo of yours? tilts can be 1 degree or say 30degres. so it's a matter of degree (no pun) ill up load more to the gallery ,under g16 title. i sadly dont have photo that ,camera level and aligned to center line of car all photos bad.. and casual no problem at all and is good question. very good. some of these cars run many engine, in one bay and mounts are custom to this car. to fit g16 with no problems that is for sure.. some engineer had to work all that out, and torque reaction effects. as you know when you accelerate the pan oil wants to move to the rear, so the deep part of pan must be at the rear and due to the rear slopping of the engine, then the pan hits the front axle. so if the engine is too tall they tilt it to one side. that is how i think they did it; using this body and frame. they do that with mounts and on the esteem , different mounts. not saying its tilted or not. if i had not sold it,would photo it , with my , carpenters level. dead ahead, photos are 2d and poor. one 4wd kick i had the rear transmission cross member looked like dog leg "bent offroading", and engine tilted.. look here? http://www.fixkick.com/bbs2/Suzuki-bbs/ezgallery.php?action=myimages&u=3 the engine itself is not tilted left or right the mounts may be, small tilt if you look at rear view above, do you see tilt? left or right?' note how pan is sculpted to fit around front drive pinion flange. see those rear block wings, see them tilt, i cant see any....? can you i could fit long pocket level behind the pan and measure tilt easy, but mines gone 7 years ago... now have JK jeep, (yes traitor.) ![]() have you gone under and gandered at trans cross member, is it smashes up. like some are, wrecked. see that flange to pan gap? if the engine tilts to far left that gets too close. and would eat the pan to death, best is to look more carefully at all parts down then, loose, bent, missing. one guy last week said, i need a rear mount"? it is a 3 point mounting system. |
