rear end roar at 40-45 mph - Printable Version +- Car Repair Forum (https://fixkick.com/forum) +-- Forum: Suzuki (https://fixkick.com/forum/forum-suzuki) +--- Forum: Sidekick/Tracker (https://fixkick.com/forum/forum-sidekick-tracker) +--- Thread: rear end roar at 40-45 mph (/thread-rear-end-roar-at-40-45-mph) |
rear end roar at 40-45 mph - Ron Jones - 12-11-2015 I have a 1998 Chevy Tracker w/216,000 miles. 5 speed manual tran and a 4.53 rear gear. I run 215/15/70 tires. Any ideals? RE: rear end roar at 40-45 mph - fixkick - 12-11-2015 welcome ! joking im on the front porch swing sip'n shine, so drive around the block 3 times, and ill text you. LOL ! in 2wd (2H?) all joking aside. could be u-joints, or any of 5 rear end bearings. or brakes dragging, makes noise going slow, find safe place and see if hand braking gently makes it change up or down noise wise. does it make noise coasting? cut throttle, moving bump shifter to N? or slam in clutch? |
