coolant leak from front freeze plug - Printable Version +- Car Repair Forum (https://fixkick.com/forum) +-- Forum: Suzuki (https://fixkick.com/forum/forum-suzuki) +--- Forum: Sidekick/Tracker (https://fixkick.com/forum/forum-sidekick-tracker) +--- Thread: coolant leak from front freeze plug (/thread-coolant-leak-from-front-freeze-plug) |
coolant leak from front freeze plug - 96Kick - 12-02-2015 Does anyone know how to remove the tube from behind the water pump housing that goes beneath the intake. I have a leak in the front freeze plug which is behind that tube on 1.6L 16 V. RE: coolant leak from front freeze plug - 96Kick - 12-02-2015 (12-02-2015, 09:55 AM)fixkick Wrote: it is a press fit to the pump Thanks, will reinstalling it without leaking be a problem? RE: coolant leak from front freeze plug - 96Kick - 12-03-2015 (12-02-2015, 10:56 PM)fixkick Wrote: well , that depends on reality Thanks again, new at Suzuki repairs. Is the "O" ring available ? And, one more important question. Will removing the manifold give me access to the front freeze plug without taking the intake off? RE: coolant leak from front freeze plug - fetcher - 10-14-2016 Two things: Anyone have a source for those tubes? It may not be the freeze plug, it could be block porosity RE: coolant leak from front freeze plug - fixkick - 10-15-2016 only (THE PIPE TUBE) made and sold by SUZUKI sorry. it not used anywhere else in the world. for sure not aftermaket ,this car is rare, and getting more rare every day, so nobody wants to invest in that. RE: coolant leak from front freeze plug - fetcher - 10-18-2016 I did not ask the blind to guess what damage is on. Maybe you have chosen to interpret what I wrote that way. I meant to mean that the individual with the leak problem should examine carefully. Depending on where a porosity leak is, it could easily mimic a freeze/casting plug issue. After having that water pump tube out and seeing how thin the metal is, I was worried that it may some day rust through and I would have a hard time fabricating a replacement. RE: coolant leak from front freeze plug - fixkick - 10-18-2016 it will never ever rust on the inside, (paint the outside and it will not either) times change. in the USA they took out all the sulfur in the fuel, so the antifeeze mix, does not go acidic every year. and all rusted ended here. inside. it cant rust at ph 7 with inhibitors in mix. buy a new car, drive 5 years, see, no more acid in the antifreeze, the kit to test it is $2. suzuki may still sell it, get them while still possible after all most the parts on this car are now discontinued. this car is in he end of life, era. the part is 177550-60x50 its $78 plus next unborn male child as usual http://www.suzukicarparts.com/parts/1995/Suzuki/Sidekick/JLX/index.cfm?siteid=214820 can take weeks to get, from deed deep warehousing, now that they bugged out. RE: coolant leak from front freeze plug - fixkick - 10-18-2016 used on many SE416 suzuki's world wide. RE: coolant leak from front freeze plug - fixkick - 11-02-2016 freeze plugs (core plugs) are metric, and solid in all stores, world wide. (auto stores) |
