washer down #2 cylinder - Printable Version +- Car Repair Forum (https://fixkick.com/forum) +-- Forum: Suzuki (https://fixkick.com/forum/forum-suzuki) +--- Forum: Sidekick/Tracker (https://fixkick.com/forum/forum-sidekick-tracker) +--- Thread: washer down #2 cylinder (/thread-washer-down-2-cylinder) |
washer down #2 cylinder - mikedalcollo - 11-22-2015 I made a dumb mistake, a washer fell down my#2 cylinder while my spark plug was out! I'm at tdc #1....would I be able to get to it through the exhaust or intake mani? 96 tracker, 1.6 any help would be appreciated! RE: washer down #2 cylinder - fixkick - 11-22-2015 hope it steel use magnet on a stick. thru spark hole, tdc or btc. the washer will not go up hill to head , no running. put cylinder to btc, and see if you can see it with a flash light, i you can see it , you get it. mag stick or the prong stick. claw pickup tool... http://www.craftsman.com/craftsman-23-1-2-in-pick-up-tool/p-00941322000P?sid=IDxCMDFx20140801x001&KPID=00941322000 RE: washer down #2 cylinder - mikedalcollo - 11-22-2015 it was on the end of the mag stick I use to get plugs out, it fell off in the process. won't do that again. stick is too big to get that far in. will get something smaller. so if that doesn't work.....head off? RE: washer down #2 cylinder - mikedalcollo - 11-22-2015 got it! was lucky this time. note to self....use plug wire f socket won't get it. thanks for the reply! RE: washer down #2 cylinder - fixkick - 11-22-2015 goooddddddddddddd! very good, i once sucked in a small rag there, but it burned up end blew burning rag out tail pipe, with buddy watching and never forgetting.... RE: washer down #2 cylinder - mikedalcollo - 11-22-2015 wowee, that WOULD be unforgettable! |
