welding a broken clutch pedal back together - Printable Version +- Car Repair Forum (https://fixkick.com/forum) +-- Forum: Suzuki (https://fixkick.com/forum/forum-suzuki) +--- Forum: Sidekick/Tracker (https://fixkick.com/forum/forum-sidekick-tracker) +--- Thread: welding a broken clutch pedal back together (/thread-welding-a-broken-clutch-pedal-back-together) Pages:
welding a broken clutch pedal back together - woolverton - 09-26-2015 Hi, I’m new here and new to Sidekicks/Trackers. I have read almost every FixKick webpage (so much great info; thank you FixKick!) and much of these forums but still cannot find some answers. If I’m a blind idiot please point me in the right direction. I’ve picked up a 1997 Tracker cheap because the clutch pedal has broken …again. 1997 Geo Tacker base 4 door, 5-speed, 4WD [VIN 2CNBJ12666V690…] Square end clutch pedal rod. 1. I cannot find anyone selling the pedal (arm & rod) or the pedals assembly. Is anyone still selling parts? 1b. So many part numbers on FixKick (Thank you!) but I’m not sure which one/ones are correct— 49810-62AF1, 49810-58B21, 91173175, 91172672. 2. My clutch pedal arm has been welded once or twice before. I expect to weld it again but I don’t know the correct position/angle. Does anyone have the Arm angle position (relative to a fixed part, eg: the upper stop)? (Yes. I have a fresh clutch cable ready to install.) Thanks Stephen RE: welding a broken clutch pedal back together - fixkick - 09-26-2015 as you know.... the pedal breaks for 2 reasons, the cable is bad, (I goes bad inside where no man can see) the cable inside gets a deep groove, and pinches the internal cable, badly.... or the stock crappy 2 point spot weld fails on pedal. (these two facts help (sick) each other) Suzuki still sells the pedal. (not sure on GM, which is same but diffr. P/n and is missing im my Geo book.) last time i checked, 1year ago? they had them. since you you show fulls spec on car this is easy to p/n exact. 5sp, 4door, (ill answer for non cruise option) there are 2 numbers, one japan and one CAMI the CAMI is best number IMO 49810 prefix both dash 62a52 japan dash 62AF1 Cami 49810-62AF1 (bingo) shows here. http://www.suzukicarparts.com/parts/1995/Suzuki/Sidekick/JS/index.cfm?siteid=214820 thanks your welcome, as always... RE: welding a broken clutch pedal back together - woolverton - 09-28-2015 After replacing my clutch cable the clutch is still in heavy drag. So on to that pesky clutch pedal. With FixKick’s guidance I contacted Suzuki Depot. Denise was incredibly patient during locating my clutch pedal details. She even pulled the part and sent me a photo of the shaft end to confirm it matched my Tracker’s. After I placed my order she followed up with the full pedal assembly (clutch, brake, gas) exploded view by email. Wow, I don’t ever recall getting such excellent service from a parts retailer. Denise, Suzuki Depot/Tom's Truck Center 12221 Monarch St Garden Grove, Ca. 92841 (800)238-9308 Stephen 1997 Geo Tracker four door, five speed, all wheel drive, cruise control, and just a little bit of rust …everywhere RE: welding a broken clutch pedal back together - fixkick - 09-28-2015 thanks! for that shaft end, photo. some have splines.. thanks to one contrib.named mike. we have these nice shots. too http://www.fixkick.com/tranny/clutch/mikes-clutch91/shrunk/html/index.html other pedal drag causes.? 1: collapsed throw out bearing 2: or bearing just jamming on its guide (front of trans) 3: or the clutch disk spline jamming. (it bad or the splined pilot shaft galled) 4: damage to the forked, throw out actuator rod, assembly, or bushing failure there, or one fork busted off or bent. RE: welding a broken clutch pedal back together - woolverton - 10-04-2015 (09-26-2015, 11:18 AM)woolverton Wrote: Does anyone have the Arm angle position (relative to a fixed part, eg: the upper stop)? I have my new 49810-62A52 clutch pedal. So others can repair their pedals here’s the relationship between arm and shaft square end: [ ignore the “UP†markings on the box :-) ] Stephen 1997 Geo Tracker 4-door, 4X4, 5-speed RE: welding a broken clutch pedal back together - fixkick - 10-04-2015 superrrrrrrrrrrrrrrrrr! thanks RE: welding a broken clutch pedal back together - woolverton - 10-04-2015 I’m pulling out my old pedal. [The PO welded it back but at ~25° off!] The pedal swings smoothly in the assembly. The shaft slides in its sleeve. BUT… the shaft will not come out any further than the last little bit! Am I missing something? Is there a trick to this? RE: welding a broken clutch pedal back together - GeoHacker - 10-05-2015 (10-04-2015, 09:17 AM)woolverton Wrote: I’m pulling out my old pedal. [The PO welded it back but at ~25° off!] Is the continued slide outward being blocked by something on the opposite side of the shaft preventing it from going further? Hitting that black panel stuff? Only other thing you'd think would be if shaft there at the splines/bolt area is out of round, bent, or has a burr or something keeping it from entering that final portion so it can exit? Wish I could help more. Nice pics you've posted. RE: welding a broken clutch pedal back together - woolverton - 10-05-2015 (10-04-2015, 09:17 AM)woolverton Wrote: I’m pulling out my old pedal. answer: get a bigger hammer RE: welding a broken clutch pedal back together - GeoHacker - 10-06-2015 (10-05-2015, 01:53 PM)woolverton Wrote:(10-04-2015, 09:17 AM)woolverton Wrote: I’m pulling out my old pedal. Ha. Glad you got it worked out. In my situation, smacking on my final bearing, the 1/2 pound dead blow worked better than the 2-3 pound rubber mallet. Though earlier, the rubber mallet set the countershaft just right. Great looking pedal. NAPA carries nice rubber pads for Tracker brake and clutch pedals, $3 I think. Now my foot won't slip off the clutch after rain anymore. I am going to buy a spare set in case they go away. |
