Is it possible to replace MAF's thermistor? - Printable Version +- Car Repair Forum (https://fixkick.com/forum) +-- Forum: Suzuki (https://fixkick.com/forum/forum-suzuki) +--- Forum: Sidekick/Tracker (https://fixkick.com/forum/forum-sidekick-tracker) +--- Thread: Is it possible to replace MAF's thermistor? (/thread-is-it-possible-to-replace-maf-s-thermistor) |
Is it possible to replace MAF's thermistor? - Nexustrax - 09-15-2015 Hi everybody, I am new to the forum, not to the website anyway...precious resource, thanks. My MAF's (13800-58B00, Vitara 1.6 16v) thermistor has been blown away, because of an LPG backflame, I guess. Given the price of the good MAFs, I would like to ask you if you think it is possible to replace the thermistor only, and, in this case, where can I find its specifics. Thank you! RE: Is it possible to replace MAF's thermistor? - fixkick - 09-15-2015 impossible there is no spec. on it or source. ouch flame back failure, sounds like too lean. how can LPG run with a stock ecu and MAF, impossible. that. my guess is car is dual fuel setup. and the LPG side blew up the Gas side, dang that is a first here... sorry it happened to you. buy a used maf of fleabay is best change, and not the clone its no good. the get harder an harder to find or buy the CARDONE rebuilt. for 1/3 suz. price. RE: Is it possible to replace MAF's thermistor? - Nexustrax - 09-15-2015 Yes, it is dual fuel. I will follow your advice, then. Harder and harder to find, you're right! Thanks again (09-15-2015, 12:59 AM)fixkick Wrote: impossible RE: Is it possible to replace MAF's thermistor? - Deadduck - 09-19-2015 I got brand new mass airflow sensor OEM mitsi product here in nz for $300Nzd all up there must be some auto electrical place that sell OEM ones over there RE: Is it possible to replace MAF's thermistor? - fixkick - 09-20-2015 5 times cheaper that here.! 192USD over $1100 USD here. (suzuki sales counter) but we have good old CARDONE that rebuilds them... and 100% tested. the insides are not documented, it's a Mitsubishi secret. china tried to do it and failed. here is the china hack job. (revealed) http://www.fixkick.com/sensors/china-maf/cloned-maf.html as you can see the thermistors are factory trimmed, "calibrated" so replacing one, would need to be re calibrated. this schematic is not from any Mitsubishi. |
