Vitara 1.6i16v G16b Timing issues - Printable Version +- Car Repair Forum (https://fixkick.com/forum) +-- Forum: Suzuki (https://fixkick.com/forum/forum-suzuki) +--- Forum: Sidekick/Tracker (https://fixkick.com/forum/forum-sidekick-tracker) +--- Thread: Vitara 1.6i16v G16b Timing issues (/thread-vitara-1-6i16v-g16b-timing-issues) |
Vitara 1.6i16v G16b Timing issues - Mdkbaltas - 07-16-2015 Hello Friends Im from portugal and im a vitara fan. Your forum is one of the best sources of suzuki info. recently i started to recondition my hardtop 1996 3door blue vitara G16b. it has 140000km and i didnt know what service the previous owner had done to it so i started changing the timing belt and water pump. My problem started when after disassemble all surroundings and removing sparkplugs i could not set the TDC marks bt 2 notch because a very strong resistance with spring effect. Or in other words, when i was reaching the tdc rotating the cranck CW i feel a spring effect that reverse my rotation and didnt allow me to reach the perfect tdc. Have any of you ever had similar problem? Thansk for your help RE: Vitara 1.6i16v G16b Timing issues - fixkick - 07-16-2015 are you sure its G16 16valve or is it 8 valves.? my web page uses USA years, out side USA. the 8v engine was used for many years after 1995, up to 2004 ? BIAS: the 8v engine will do that and requires loosing the valve lash adjusters, because of the missing 8 other valves and 8v bias pushing back. if truly an 16v engine and it pushes back ,the cam then my guess is the I/E marks are wrong on the cam cog drive wheel. please tell me valve count for sure....? RE: Vitara 1.6i16v G16b Timing issues - Mdkbaltas - 07-16-2015 Thanks for your quick response. Im sure it is a 16v. But even if the cog marks are wrong, the engine was working, and even before i remove the belt i was with the same problem! Here some photos What do you reckon of it? |
