1994 SIdekick JLX 5dr automatic with o/d will not engage reverse gear. - Printable Version +- Car Repair Forum (https://fixkick.com/forum) +-- Forum: Suzuki (https://fixkick.com/forum/forum-suzuki) +--- Forum: Sidekick/Tracker (https://fixkick.com/forum/forum-sidekick-tracker) +--- Thread: 1994 SIdekick JLX 5dr automatic with o/d will not engage reverse gear. (/thread-1994-sidekick-jlx-5dr-automatic-with-o-d-will-not-engage-reverse-gear) |
1994 SIdekick JLX 5dr automatic with o/d will not engage reverse gear. - Sent - 06-15-2015 I have a 1994 Suzuki Sidekick 5 door 4 RE: 1994 SIdekick JLX 5dr automatic with o/d will not engage reverse gear. - fixkick - 06-15-2015 ATF levels ok filter clean? dirty filters make the pump weak, and low pressure might effect reverse, more....? shift linkage adjusted correctly. must be if the others work. it put in a new filter, and have hope.... |
