95 Sidekick (No Crank/Wont start) Anybody help?? - Printable Version +- Car Repair Forum (https://fixkick.com/forum) +-- Forum: Suzuki (https://fixkick.com/forum/forum-suzuki) +--- Forum: Sidekick/Tracker (https://fixkick.com/forum/forum-sidekick-tracker) +--- Thread: 95 Sidekick (No Crank/Wont start) Anybody help?? (/thread-95-sidekick-no-crank-wont-start-anybody-help) |
95 Sidekick (No Crank/Wont start) Anybody help?? - Mac611 - 03-02-2015 Hello folks any and all suggestions or advice would be greatly appriciated. Have a 1995 Sidekick, auto tranny, 200K miles, was starting and running pretty good then one day I pulled across the street shut it off and it didnt start for a hr. or so did this for 3 days now it wont start (or crank) at all. Nothing!! Today I replaced the starter and the same thing Nothing, The only noise I hear when I turn the key is a click near the left side of the dash by the fuse box?? Any help or advice sure would be appriciated. Thank You RE: 95 Sidekick (No Crank/Wont start) Anybody help?? - fixkick - 03-02-2015 Welcome !!! did you try cranking in Neutral PRNDL lever to N.? the key line is dead. if battery terms are clean, and battery charged to 12.6vdc rested. you can hot wire the (keys in pocket) the stater solenoid. http://www.fixkick.com/nocrank.html#key-line if this test passes, cranks fast, the starter ,battery and cables are all good. leaving just one cause, the key line is dead. top reason is PRNDL failure. (or alarm hacks) last is key switch. (due to complex fix, last) or use a voltmeter to find it. RE: 95 Sidekick (No Crank/Wont start) Anybody help?? - Mac611 - 03-03-2015 (03-02-2015, 10:22 PM)fixkick Wrote: Welcome !!! Yes, It starts with the bump of a screw driver across the starter post, and yes ot did start a few time in neutral & Park. Does the vehicle have a starter relay? if so where is it located? as every pic I look at it points to the silinoid for the relay, I thought a silynoid was a silynoid and a relay was a relay. Thanks again for your help RE: 95 Sidekick (No Crank/Wont start) Anybody help?? - Mac611 - 03-03-2015 (03-03-2015, 12:55 AM)Mac611 Wrote:(03-02-2015, 10:22 PM)fixkick Wrote: Welcome !!! Weird Just weird it now had a funny idle and the check engine light came on so I tapped the MAF sensor and the check engine lite went off, Idles perfect and starts now.. Weird Just Weird.. Thanks for the help. All is fine here now. |
