Brake Pedal going down too far! - Printable Version +- Car Repair Forum (https://fixkick.com/forum) +-- Forum: Suzuki (https://fixkick.com/forum/forum-suzuki) +--- Forum: Sidekick/Tracker (https://fixkick.com/forum/forum-sidekick-tracker) +--- Thread: Brake Pedal going down too far! (/thread-brake-pedal-going-down-too-far) |
Brake Pedal going down too far! - Zackman - 01-28-2015 Hello again (two issues in the same day!) My son's Zuke's brake pedal goes down quite a bit. I have fully bled the lines twice, but a little improvement was resulted. Would the culprit be a worn master-cylinder? Your views are appreciated. Regards, Zackman! RE: Brake Pedal going down too far! - fixkick - 01-28-2015 If you can get a hard pedal ,even key off (manual mode ) it needs no bleeding. if pedal drifts to the floor, bad MC or leaks somewhere, beyhond mc. if spongy,? it's air is system i'd get manual mode ok first, then play with booster running later. your welcome, be safe ! RE: Brake Pedal going down too far! - barnbiketom - 01-28-2015 rear brake adjusters bad..??? rear brakes way too loose cause low pedal..they have to 'catch up' to the front before it stops RE: Brake Pedal going down too far! - fixkick - 01-28-2015 sure , and most will be jammed bad, i had to replace mine, from suzuki stock. i think dorman makes them. too. the 91 is automatic, in 96 its manual its got these simple aligatator teeth.' one way to prove this is use the hand brake, to take up all slack and feel foot brake. ![]() ![]() photo of real 2door 91 |
