clutch pedal shaft arm removed - Printable Version +- Car Repair Forum (https://fixkick.com/forum) +-- Forum: Suzuki (https://fixkick.com/forum/forum-suzuki) +--- Forum: Sidekick/Tracker (https://fixkick.com/forum/forum-sidekick-tracker) +--- Thread: clutch pedal shaft arm removed (/thread-clutch-pedal-shaft-arm-removed) |
clutch pedal shaft arm removed - arkhamsjoker - 12-04-2014 The clutch pedal shaft arm has been removed from the clutch pedal shaft without any index marking. My Q is, if I reinstall it and it is not exactlly where it should be, will I be able to adjust cluth pedal free play, clutch pedal position, and clutch cable by using the methods given in the Factory Service Mannuals. RE: clutch pedal shaft arm removed - fixkick - 12-04-2014 the shaft end is clearly marked. if off one way, the cable dont fit if off the other , its short strokes the clutch or if off, is non linear. (horrid effect , seen it) here are all marks. http://www.fixkick.com/tranny/clutch/mikes-clutch91/shrunk/html/image_2.html the lever is has a punch mark and so does the end of shaft. i guess, if lost, marks set the bottom cable to mid, adjustment range. then fit the top lever to spline so all slack it gone, and pray. GRIN ! RE: clutch pedal shaft arm removed - arkhamsjoker - 12-05-2014 Thanks for the reply, found the marks. Maybe the time spent in prayer should be for better eyesight. RE: clutch pedal shaft arm removed - fixkick - 12-05-2014 im so glad, after all the parts are hard to get, (not in stock or long delays at suzuki) some are so warn out that playing light at different angles works.... |
