replacing cv axles - Printable Version +- Car Repair Forum (https://fixkick.com/forum) +-- Forum: Suzuki (https://fixkick.com/forum/forum-suzuki) +--- Forum: Sidekick/Tracker (https://fixkick.com/forum/forum-sidekick-tracker) +--- Thread: replacing cv axles (/thread-replacing-cv-axles) |
replacing cv axles - Azplinker - 11-25-2014 I have a '92 4sp automatic 4x4 1.6 MFI Sidekick. are there any special tools required to remove and replace the front axles? RE: replacing cv axles - fixkick - 11-25-2014 Both>? im not sure what you are doing, the CV axles are bad. tell what is bad first. so i can know job. none , are special, unless pulling front wheel bearings. I have never attempted to remove CV axle assemblies, using all 3 ways, only 4c-8 way 1: FSM way, 2 drop axle. , 3 drop inboard side of Arm. the snap ring is #34 here, is off first. http://www.fixkick.com/axles/Pan-drop/pandrop.html#cv and that begs the question, which way? are you doing this drop ball is FSM way page 4C8 drop whole axle like seen here http://www.fixkick.com/axles/Pan-drop/pandrop.html you could drop the Arms from ball side or rear of the A side. dealing with spring tension. or use the FSM way. its publish, and free to look. http://www.acksfaq.com/96-FSM-v1-4c-pdf.htm read page 4C-8 and ask questions. snap ring off. you drop the arm ball end. then mark parts. then drop inboard cv flanges. page 4c-8 http://www.acksfaq.com/96-FSM-v1-4c-pdf.htm then pull the axle. type CV in my search box, there. RE: replacing cv axles - Azplinker - 11-25-2014 The CV boots are both damaged from age, mileage. I have complete axle assembles to replace them. I didn't understand if I needed any special tool to remove outer axle shafts from wheel hub or not. Will drop the ball joint and remove that way. Thanks for the clarification. RE: replacing cv axles - fixkick - 11-26-2014 sure you need tools. sure. special no. all are off shelf at your friendly auto store, (wheel bearings , excepted) good not rebuilding yours. that is more steps. floor jacks and stands wrenches, snap ring tool ,expanding the axle have only 2 captive points, the snap ring and the inboard mounts. for joint rework check this out http://www.acksfaq.com/cvhalfshaft.htm |
