No high idle when cold - Printable Version +- Car Repair Forum (https://fixkick.com/forum) +-- Forum: Suzuki (https://fixkick.com/forum/forum-suzuki) +--- Forum: Sidekick/Tracker (https://fixkick.com/forum/forum-sidekick-tracker) +--- Thread: No high idle when cold (/thread-no-high-idle-when-cold) |
No high idle when cold - Steve - 10-22-2014 Hello all, I am having trouble with my 1995 16v sidekick. I cannot get the engine to idle high when cold. When it starts it goes directly to 800rpm. Makes warming the engine difficult on cold mornings. It will drive fine just no high idle when cold. I will appreciate any pointers anyone can give. Thanks RE: No high idle when cold - fixkick - 10-22-2014 welcome Steve. the IAC under the TB is dead. that assumes the engine is not flooding and misfiring (shaking too) at idle. (eg. fuel pressure stuck at 60psi , bad FPreg)) or grossly lean. say real low fuel pressure. if the air fuel ratio is ok, then the IAC is stuck closed. test in a pan of hot water this hole must be open , cold until about 150F http://www.fixkick.com/fresh-air/Slide_Show/HTML/image_23.html http://www.fixkick.com/fresh-air/Slide_Show/HTML/image_28.html dead cold engine. off the huge air tube. up top find a large rubber hoes that fits on that TB , rectangle port, and blow in that hole, if you can not blow into that hole , the IAC is stuck closed. good luck and cheers ! |
