Engine & tranny 94 to 96 swap question - Printable Version +- Car Repair Forum (https://fixkick.com/forum) +-- Forum: Suzuki (https://fixkick.com/forum/forum-suzuki) +--- Forum: Sidekick/Tracker (https://fixkick.com/forum/forum-sidekick-tracker) +--- Thread: Engine & tranny 94 to 96 swap question (/thread-engine-tranny-94-to-96-swap-question) |
RE: Engine & tranny 94 to 96 swap question - fixkick - 10-29-2014 bingo if yours looks like this, its still stock that red part is the cut off front propeller shaft, they torched it off, (a harmless act) RE: Engine & tranny 94 to 96 swap question - zukitrek - 10-29-2014 Looking forward to find out. Cheers!! RE: Engine & tranny 94 to 96 swap question - fixkick - 10-29-2014 happy hunting and good luck. RE: Engine & tranny 94 to 96 swap question - zukitrek - 10-29-2014 Bingo!! Stock tranny with the adapter for a front wheel drive. Is good to know what you have. Thanks!! RE: Engine & tranny 94 to 96 swap question - fixkick - 10-29-2014 ok your car is 4wd, and is still stock , no missing parts, no wrong parts. no swapped odd parts. (my wild presumptions) so i looked in the EPC (huge parts catalog for suzukis, 92-98 what changes were made with just your car. (4speed/related changes only) 1998 the outside case 4speed cooler lines changed. (dont care) the gear shift levers seems to change 3 or 4 times (who cares?) the transmission 4 case output shaft on the transmission changed at a specific year and vin. thie B01 shaft eg1: S6406487~ S means year code S 1995... and the number are the cars serial number. prefix. i have no idea what was changed in this shaft, rumor says ,stronger.... but its not the splines! changed , so is ok, in year, 1994 (code R vin) they changed the Kickdown valve. (no idea why or what this does, but who cares. ) related: the transfer case, output shaft changed teeth in 1996,, NEW SPLINE count (lower) (so if used 96 4sp is bought with xfr case, this case is no good. use old xfr case) and the means the rear prop drive shaft changed to match this new SPLINE, in 1996 (so get the newer year 4sp+xfr case with rear drive shaft?) conclusion: other than minor changes, the 92-98 4speed box can be swapped, 4wd, (IMO , in my opinion, but swaps are complex) I do not have access to the "Hollander" wreckers data base for parts swaps. so can not look that up. http://audatex.us/product.asp?PageID=zhollander_portal all i can do use use car-parts.com seen here. http://www.car-part.com/cgi-bin/search.cgi i see they exclude, 1996 and newer 4speeds this can be just for smog laws reasons (shift points do effect that). not just fit and works. In general: the word fit has many meanings Direct stock OE swap, no issues, at all. Direct with minor issues. (say, outside lines and vents need minor work) wont fit but can if drive shaft or transfer case swapped. needs a rewire. has wrong solenoids. has wrong PRNDL switch, (use old one?) wrong TC clutch. not smog illegal (mostly a California issue) and more. now the really wild ideas but one can learn by others doing wild swaps. -------------------------------------------(left field)---------------------------------------- wireless means NO TCM brain. he means a real hydramatic trans, old school. folks do this , in desperation, or have access to lots of cheap wrecked cars. http://bbs.zuwharrie.com/content/topic,68191.0/nowap.html your 4speed is really a Toyota mostly owned, A40 series box. and, was used in many other cars. (even your teachers Volvo, LOL) your box is really a A44DE, with the 4wd adapter added. that be it. RE: Engine & tranny 94 to 96 swap question - zukitrek - 10-29-2014 Great info sir. Very helpful as always. J RE: Engine & tranny 94 to 96 swap question - fixkick - 11-06-2014 Suzuki factory orders the trans, with the p/n codes that get them the transfer case adapter, that fits the SUZUKI transfer case. 03-72LE is that number. e means electronic. base trans is A44 , it gets coded up to make it a SUZUKI 4peed. |
