Engine & tranny 94 to 96 swap question - Printable Version +- Car Repair Forum (https://fixkick.com/forum) +-- Forum: Suzuki (https://fixkick.com/forum/forum-suzuki) +--- Forum: Sidekick/Tracker (https://fixkick.com/forum/forum-sidekick-tracker) +--- Thread: Engine & tranny 94 to 96 swap question (/thread-engine-tranny-94-to-96-swap-question) |
Engine & tranny 94 to 96 swap question - zukitrek - 09-12-2014 Fix can I change my 94 engine to a 96 and also an A/T tranny for the same year, what else would need to change? Thanks!! RE: Engine & tranny 94 to 96 swap question - fixkick - 09-12-2014 a record question for simple to ask and endless answers. huge issues. but alas, many have asked. the 96 engine fits all 16v cars. 92 to 98, (just the long block, not manifolds) just ignore the CKP sensor there. (pan/pump and CKP are new) only 92-95 to 96 and newer is hard,wrong pan/pump. backwards is no issues. here are more ways. http://www.fixkick.com/SWAPS.html#G16Bswaps the 4sp is a 4speed. they did not change it at all. it bolts in and plugs in but 2wd and 4wd are not same from tail shaft housing back. (and maybe the shaft too) RE: Engine & tranny 94 to 96 swap question - zukitrek - 09-12-2014 Yes I forogot mine is a 2WD. Did they make 96's also 2WD? RE: Engine & tranny 94 to 96 swap question - fixkick - 09-12-2014 i forgot what was up. and yes all years have 2wd , at least to 2005. (google the cars specs, on newer) USA answer, there are 53 countries and 4 factories, and for SURE this varies world wide.. what country is yours, i forgot. ok bad A/T , (ever try a new clean filter , yet?) you'd pull a tranny before a filter? 2wd 16v 4doors ? (5 doors by Euro parlance) issues with transmissions, all 4speed, all Trackicks, and vitara's they are 2 rear prop shafts. (4doors only, more if looking at 2dr) at the rear. there are 2 4speeds used, world wide. for 2wd cars. and 4wd. when buying a tranny, 4speed you need to LOOK at yours. first. see photo below see red circle.? there are 2 adaptors. as you may not know Aisin makes this tranny with no tail and the car makers adds the tail for their APP. so, there is the fast flare tail and the tapered flare... this is what must be known, before you buy. ![]() some 4speed in the wild have this. ![]() same tranny but with all different , extensions and prop shafts. never buy a tranny unseen with you naked eyes. at the least. starting in 2005 there is no answer. to 2wd it varies by country see that wiki on this vary complex subject. http://en.wikipedia.org/wiki/Suzuki_Escudo "but a 3-door version is also available in some markets. In some markets the 3-door variant drops the "Grand" to be branded simply "Vitara". In some countries, including Chile the 5-door version is named "Grand Nomade"." key word, SOME. RE: Engine & tranny 94 to 96 swap question - zukitrek - 09-13-2014 Nop filter is first. Im just looking at it as a far possibility. Local shops would cost about a little bit more than a new refurbished tranny. My country is Puerto Rico. I had a 94 sunbird that was slipping heavily and one local shop estimated repairs for around $2000 about three years ago. I'v seen refurbished trannys for have that price. But no tranny yet, I would do filter first. Too many improvised expenses are delaying it, but will do soon. Thanks for all the info though. J RE: Engine & tranny 94 to 96 swap question - fixkick - 09-13-2014 is this car a real PR, market car? called and E60? see 24 here if 60 there, thats a real PR car. fire wall tag. http://www.fixkick.com/specs/Body-TAGS/images/95-H20A-VG.jpg this helps get the correct parts. RE: Engine & tranny 94 to 96 swap question - zukitrek - 09-13-2014 Ok that would be nice to know. I'll let you know once I get home. J RE: Engine & tranny 94 to 96 swap question - fixkick - 09-13-2014 no hurry, just knowing what market car it is, can help. e60 is PR E03 usa fed , this 2 have a VIN tag. fed and cal. E33 usa cal e28 canada. RE: Engine & tranny 94 to 96 swap question - fixkick - 09-15-2014 here is my upgraded slush pump page, this the first bullet-ed table for checks. http://www.fixkick.com/slush-pump.html the Market codes is here. 24 is Australia , 60 is PR. http://www.fixkick.com/specs/Body-TAGS/html/image_18.html RE: Engine & tranny 94 to 96 swap question - zukitrek - 09-16-2014 Well my tag is missing. Went to look for it friday but no where to be found. My car is a Fed according to the under the hood sticker I sent you a long time ago. Where else could I look for? J |
