Pic of Walker Stainless Exhaust - Printable Version +- Car Repair Forum (https://fixkick.com/forum) +-- Forum: Suzuki (https://fixkick.com/forum/forum-suzuki) +--- Forum: Sidekick/Tracker (https://fixkick.com/forum/forum-sidekick-tracker) +--- Thread: Pic of Walker Stainless Exhaust (/thread-pic-of-walker-stainless-exhaust) |
Pic of Walker Stainless Exhaust - cosmic_splatter - 08-28-2014 Here's a pic of the walker stainless exhaust. Part number 55123 for my 95 tracker. The installed muffler is shown next to it. They did a good job keeping the original lines. One modification I will have to make it to get a new bolt for the rear most hangar since Walker uses a welded loop which is much bulkier than the factory hangar of 1/8 steel. My muffler arrived pretty beat up from amazon. I had several dents in the side. Not sure it will impact the performance, but I'm definitely going to seek a refund on some of it! It also had a sticker showing that it was a customer return from somewhere. It looks like it was shipped several times and has a lot of battle scars. Current muffler versus new one.... ![]() Dents in side of muffler. It seems to be performing ok. Should I trust it?... ![]() ![]() Amazon is going to send a replacement exhaust. ![]() Amazon is shipping a new one. ![]() Installed on car. Will remove when replacement arrives. It's about a 20 min job to swap these out now that the bolts are new! I had to drill out the old bolts on the catalytic convertor.
RE: Pic of Walker Stainless Exhaust - hatchetman - 08-28-2014 since it's "SST", no plating, dents are mostly , just "character" no plating to crack off, inside ,unseen. (if it dont rattle, its probably good) |
