IAC hose part numbers.... - Printable Version +- Car Repair Forum (https://fixkick.com/forum) +-- Forum: Suzuki (https://fixkick.com/forum/forum-suzuki) +--- Forum: Sidekick/Tracker (https://fixkick.com/forum/forum-sidekick-tracker) +--- Thread: IAC hose part numbers.... (/thread-iac-hose-part-numbers) |
IAC hose part numbers.... - cosmic_splatter - 08-18-2014 Anyone have the suzuki part numbers for the IAC hoses on each side of the little box? Probably a good idea to replace mine after 140k miles. John RE: IAC hose part numbers.... - fixkick - 08-18-2014 sure, its in the suz parts list. and at GM< 16v i made this one long ago http://www.fixkick.com/t-belt/hosed.html ISC means electric valve, not thermo only IAC. the offical parts list calls the ISC hoses, ISC hoses but the IAC are called, throttle inlet and outlet. hoses. gm (geo) has 63 items of hoses, and only few in drawings.... sadly and looking there, non for IAC. not one hose. find a GM cat, and get the num then search that way, many times they have it but dont list it. these old cars never got 100% coverage in the new databases. fact. same with Suzuki, get a real cat. and look up the number then search on line, most times a hit. but do ask me , i can look them up. Suzuki ask for a VIN your vin it GM. they can not match parts to your vin, that takes, skill. (books and knowing what parts are same) i make no claim to skill but can try. for you. |
