Rear diff drain plugs and fill plugs... - Printable Version +- Car Repair Forum (https://fixkick.com/forum) +-- Forum: Suzuki (https://fixkick.com/forum/forum-suzuki) +--- Forum: Sidekick/Tracker (https://fixkick.com/forum/forum-sidekick-tracker) +--- Thread: Rear diff drain plugs and fill plugs... (/thread-rear-diff-drain-plugs-and-fill-plugs) |
Rear diff drain plugs and fill plugs... - cosmic_splatter - 08-18-2014 I received my fill plug from Lehman suzuki. It looks like the exact replacement. Not sure what happened to the drain plug, but the part they sent doesn't look anything like the rear diff drain. ![]() The correct part should be 09246-16010, but they sent something different. Go figure. John RE: Rear diff drain plugs and fill plugs... - fixkick - 08-18-2014 keep in mind SUzuki does not sell parts for GM GEO cars, in fact , knows zero about them. (baring some odd guy there that loves them) all GEO books use unique part numbers from Suzuki. so ordering from Suzuki takes books, parts books or the E Cat. some of this parts on right look wrong to me. but now i think not. they just recently changed all part-numbers like GM did years ago and same deal, CHAOS. Suz. info. the front and rear plugs are same. USA spec cars. suz. actual old suz p/n are 09248-20003 filler 09168-20003 seal ring, (was nylon, no copper>=?) gee its improved, mine love to crack, 09246-16010 drain GM may sell these parts, but you need to look at there books. i have a book but the numbers are all bad, now, and GM lost the receipt on conversion... sadly here is the GM page note how the drain and filler, are somehow magically missing today http://www.gmpartsdepartment.com/parts/1995/Geo/Tracker/LSi?siteid=214533&vehicleid=72026&diagram=T006105&diagramCallOut=13 ah but the rear filler is shown http://www.gmpartsdepartment.com/parts/1995/Geo/Tracker/LSi?siteid=214533&vehicleid=72026&diagram=GJ89327&diagramCallOut=1 but not the drain. on rear. i did a F6 search in the SUZ database, and this drain plug above fits all 1992 vitara in UK and France and many other countries, but not USED usa. part was never used here. fits front but not rear, read on UK has "A" revison code. my guess, it it fits. just has external hex head, Nicer, really ' not used, does not mean not fit. see? but the front axle casing and ours have diff p/n A02 for france, and usa is A10, what that means, is anyones guess. remove old drain plug and try new. if it dont fit, then order it again, and say, no subs. i want the 09246-16010 drain , not the 47 drain, thank you. |
