TPS Aftermarket solution.... - Printable Version +- Car Repair Forum (https://fixkick.com/forum) +-- Forum: Suzuki (https://fixkick.com/forum/forum-suzuki) +--- Forum: Sidekick/Tracker (https://fixkick.com/forum/forum-sidekick-tracker) +--- Thread: TPS Aftermarket solution.... (/thread-tps-aftermarket-solution) |
TPS Aftermarket solution.... - cosmic_splatter - 08-03-2014 fixkick, Here is a top view of my tps sensor for my 95, 4x4, fed. http://www.fixkick.com/bbs2/Suzuki-bbs/gallery/387_02_08_14_8_48_53.jpeg It does appear that it is the "fat body" style tps as you so rightly surmised. Should I just bite the bullet on this one and purchase it from Suzuki? Or, are there good aftermarket solutions? thanks, John A view from the back of the engine... http://www.fixkick.com/bbs2/Suzuki-bbs/gallery/387_02_08_14_8_52_40.jpeg RE: TPS Aftermarket solution.... - fixkick - 08-03-2014 that is the old style TPS, good, has orig, Throttle body ! id not replace the tps unless it hesitates or idle switch fails. not me. darn things are very very expense. RE: TPS Aftermarket solution.... - cosmic_splatter - 08-03-2014 Why is the original a better throttle body? RE: TPS Aftermarket solution.... - fixkick - 08-03-2014 no the new TB you have is mono port, about 100 x easier to clean than say a 1994 quad port. intake, Hidden paths in it..... |
