Bosch 02 Sensor, 22MM or 7/8" bolt? - Printable Version +- Car Repair Forum (https://fixkick.com/forum) +-- Forum: Suzuki (https://fixkick.com/forum/forum-suzuki) +--- Forum: Sidekick/Tracker (https://fixkick.com/forum/forum-sidekick-tracker) +--- Thread: Bosch 02 Sensor, 22MM or 7/8" bolt? (/thread-bosch-02-sensor-22mm-or-7-8-bolt) |
Bosch 02 Sensor, 22MM or 7/8" bolt? - cosmic_splatter - 07-27-2014 Anyone know if the bosch 02 sensor is 22m or 7/8" on the bolt? I want to purchase a socket and I read the 7/8 wrench can strip a 22mm due to the slight difference. RE: Bosch 02 Sensor, 22MM or 7/8" bolt? - fixkick - 07-27-2014 mine is 7/8" split socket, official 02 socket. just looked. RE: Bosch 02 Sensor, 22MM or 7/8" bolt? - cosmic_splatter - 07-27-2014 fixkick, I was going to try this offset style... http://www.amazon.com/gp/product/B00390BS7C/ref=ox_sc_act_title_2?ie=UTF8&psc=1&smid=ATVPDKIKX0DER And a thread chaser.... http://www.amazon.com/gp/product/B000XETMW0/ref=ox_sc_act_title_1?ie=UTF8&psc=1&smid=ATVPDKIKX0DER Would a long split socket style be better? Not sure how much room is on the side of the sensor to use an offset. John RE: Bosch 02 Sensor, 22MM or 7/8" bolt? - fixkick - 07-28-2014 what works best depends on what sensors. front or rear. cal/fed cars? all the above work, but the socket is way more strong than any spanner on earth. the split side, socket for 02s. works best. in most cases. |
