lead tin or galvanized fuel tank.... - Printable Version +- Car Repair Forum (https://fixkick.com/forum) +-- Forum: Suzuki (https://fixkick.com/forum/forum-suzuki) +--- Forum: Sidekick/Tracker (https://fixkick.com/forum/forum-sidekick-tracker) +--- Thread: lead tin or galvanized fuel tank.... (/thread-lead-tin-or-galvanized-fuel-tank) |
lead tin or galvanized fuel tank.... - cosmic_splatter - 07-24-2014 If I find that I need to replace my fuel tank, should I go with... Lead tin coating... http://www.rockauto.com/catalog/moreinfo.php?pk=17538&cc=1142266 or Galvanized coated tank.... http://www.rockauto.com/catalog/moreinfo.php?pk=1027504&cc=1142266 Any better choices for aftermarket tank? thanks, John RE: lead tin or galvanized fuel tank.... - fixkick - 07-25-2014 i think the spectra all have internal plating. check carefully, other than that, all are same. you can paint the outside of them all, but the inside, you can only buy them plated or add that Dacron, coating that classic cars and motorcycles used (Kream tanks coatings) good luck to you !!! |
