Can't find the PCV valve - Printable Version +- Car Repair Forum (https://fixkick.com/forum) +-- Forum: Suzuki (https://fixkick.com/forum/forum-suzuki) +--- Forum: Sidekick/Tracker (https://fixkick.com/forum/forum-sidekick-tracker) +--- Thread: Can't find the PCV valve (/thread-can-t-find-the-pcv-valve) |
Can't find the PCV valve - Sylvanite - 07-24-2014 I'm looking for the PCV valve so I can replace it (I assume PO did not do 50k replacement). There are several distinct PCV valves for sale on rockauto, and I think I know which one I need, but I wanted to pull the old valve first to see. The problem is that I can't find the PCV at all. I looked at the FSM and pulled the cam vent tube (leaking oil incidentally), realized my mistake, but could not find the correct one. RE: Can't find the PCV valve - fixkick - 07-24-2014 the 8v the PCV screws in the intake man..so has this large pipe thread, NPT. the 16v engine, is 100% hose fittings. and the one end going in to the top center plenum in a grommet. here is 16v (my coin toss) see that nylon deal bob there. bingo. http://www.fixkick.com/engine/97-motor-pull/images/11sideviewl.jpg 8v is in my intake, slide http://www.fixkick.com/engine/8v/vacuum%20ports/html/image_2.html both early and late. in one photo. RE: Can't find the PCV valve - Sylvanite - 07-24-2014 Thanks, I found it. In retrospect, I could have followed the huge trail of oil to the valve... Also, watch out on rockauto.com, most aren't labeled as to 8/16v, and some are labeled wrong 16v for 8v and as 2 door or 4 door. If I hadn't looked, I would have ordered the wrong one. RE: Can't find the PCV valve - cosmic_splatter - 07-24-2014 Fixkick, What paint did you use on that engine in the photo? Sure looks good! RE: Can't find the PCV valve - fixkick - 08-02-2014 none, that is shinny aluminum.... i built it up from naked , every inch. thanks! that is correct they all mix 8v./16 that is because Suzuki used same vin engine code for both. damn shame that. GM used U/6 vin codes, and cant use that on Suzuki's they go , huh? |
