Rhino diagnostic for ODB1 Trackers? - Printable Version +- Car Repair Forum (https://fixkick.com/forum) +-- Forum: Suzuki (https://fixkick.com/forum/forum-suzuki) +--- Forum: Sidekick/Tracker (https://fixkick.com/forum/forum-sidekick-tracker) +--- Thread: Rhino diagnostic for ODB1 Trackers? (/thread-rhino-diagnostic-for-odb1-trackers) Pages:
Rhino diagnostic for ODB1 Trackers? - cosmic_splatter - 07-24-2014 Anyone have any knowledge about this Rhino package for ODB1 computers on trackers? http://www.rhinopower.org/diag/sdl_if.html Looks like it's not available right now. But, it says he's working on a new system. John RE: Rhino diagnostic for ODB1 Trackers? - fixkick - 07-24-2014 its great , get it. id not own any car with OBD1 tech with out a real scan too. most cars this is easy, say any real GM or any honda made. but on suzuki this guy is a one man band, the best . if you read all the forum post there. you will see what it does. click 1st link here. http://www.fixkick.com/ECU/Tech1/full_scan2.html you can see all 32 PID live data with his tool, free software, all you get is the silly (secret) GM ALDL serial link cable, and bam your there. im made a cable the hard way once, 2007 . id not do that now.... you have to contact him and ask him for the cable. i think, guessing they only get them made when there is enough buyers.. ask him. personally. RE: Rhino diagnostic for ODB1 Trackers? - cosmic_splatter - 07-24-2014 Thanks fixkick. I sent him an email. Definitely want one. RE: Rhino diagnostic for ODB1 Trackers? - cosmic_splatter - 07-24-2014 ps Fixkick...can you purchase one of these cables and splice it to a USB cable? It looks like it may have the proper terminals. http://www.amazon.com/OBD1-OBD2-Adapter-Connector-Cable/dp/B00D82OKDK/ref=sr_1_1?s=automotive&ie=UTF8&qid=1406158410&sr=1-1&keywords=odb1+to+odb2 He gives the proper pins here.... http://www.rhinopower.org/diag/sdl.html This cable looks complete.... http://aldlcable.com/products/aldlobd1u.asp Rhino shows data on pin M. RE: Rhino diagnostic for ODB1 Trackers? - barnbiketom - 07-24-2014 I will get one also, ben on his site numerous times but no email??? how can i get hold of him???? RE: Rhino diagnostic for ODB1 Trackers? - cosmic_splatter - 07-25-2014 I sent an email to Rhino several days ago and haven't heard back. I received a call from the guy selling the GM cable and he said it should work since it's using the FTDI chipset which is needed to talk to the ecu. Signal is also on pin M like Rhino's document reveals is needed. So, I may order it today and see if it works. I will report back on it. http://aldlcable.com/products/aldlobd1u.asp John RE: Rhino diagnostic for ODB1 Trackers? - cosmic_splatter - 07-26-2014 fixkick, I did exactly what you said. I even emailed Rhino. I haven't heard back from him. John RE: Rhino diagnostic for ODB1 Trackers? - fixkick - 07-26-2014 if you discover those facts ,please do share them , im sure many will land here., via google searched,etc RE: Rhino diagnostic for ODB1 Trackers? - cosmic_splatter - 07-26-2014 There is a bunch of good info within this article. What I want to try is the Rhinoview software with the GM cable. I'm contacting the vendor of the cable to see if the driver can be set to 7812 baud. http://www.suzuki-forums.com/suzuki-sidekick-escudo-vitara-geo-tracker/27617-aldl-connector-3.html ps. Any any way to change my user id? I had a typo when I created it. I wanted cosmic_splatter, but typed cosmit_splatter. More good info found in this thread. http://www.teamswift.net/viewtopic.php?f=5&t=45016 RE: Rhino diagnostic for ODB1 Trackers? - fixkick - 07-29-2014 back from the dead. added to my new hacking page. here http://www.fixkick.com/hacking/hacked/addressmap-hacked.html answers ALL that. the answer is MAYBE, it will cost you $70 to find out. and if the Q4 equivalence part, can be tuned if it dont work. |
