engine problems need some advice - Printable Version +- Car Repair Forum (https://fixkick.com/forum) +-- Forum: Suzuki (https://fixkick.com/forum/forum-suzuki) +--- Forum: Sidekick/Tracker (https://fixkick.com/forum/forum-sidekick-tracker) +--- Thread: engine problems need some advice (/thread-engine-problems-need-some-advice) |
engine problems need some advice - newguy - 07-15-2014 i am currently working on my 1998 4 door standard sidekick with a 1.8 liter 16 valve engine. When I start up my truck i notice that there was white smoke coming out of the tail pipe. The engine seams to be rocking more than is should be. Also it drinks fuel more than it should. i was wondering if anyone has any solutions. RE: engine problems need some advice - barnbiketom - 07-15-2014 if the white smoke CONTINUES after it is warmed up , then check your coolant for loss.. head gasket/warped head ?? if it does NOT smoke after warm up, but MISSES ( or engine rocks??) then I suspect a sparkplug/wire/cap/rotor etc easy stuff. the key here is the coolant going thru the motor , out the tailpipe. you will know this answer for sure.. no guessing as it will continue all the time RE: engine problems need some advice - fixkick - 07-15-2014 if the white smoke at the tip linger its oil, if goes way fast, its steam, (glycol and water, antifreeze and smells sweet and nasty) take off the rad cap each morning before the first start, does the water drop and same with expansion tank level? bad. is the white smoke always there, only on cold starts. at exhaust end tip. RE: engine problems need some advice - newguy - 07-16-2014 (07-15-2014, 10:56 PM)barnbiketom Wrote: if the white smoke CONTINUES after it is warmed up , then check your coolant for loss.. head gasket/warped head ?? yes the smoke continues after it is warmed up. i noticed it rocks more than it usually dose i think it is the spark timing is off. ok i checked to day there is loss in coolant. yes it has a sweet smell to the tail pipe egzuast and oil or some extra gas is coming out the tail pipe. (07-15-2014, 11:18 PM)fixkick Wrote: if the white smoke at the tip linger its oil, if goes way fast, its steam, (glycol and water, antifreeze and smells sweet and nasty) yes it is a continues smoke coming out of the tail pipe. the level in the coolant has gone down a bit RE: engine problems need some advice - fixkick - 07-16-2014 a bit>? 1oz, 1/2 a quart.? and does the smoke linger, linger = OIL< steam goes away fast , watch moms tea pot, that is steam, and acts totally different thant burning oil. vastly so..... if you drip the end of the dip stick on to a hot exaust manifold this teach you how burning oil smells and act. the 1s key diagnosis is these fact, no facts, cant move one.. it continues coming out? , even on a fully hot engine, and after a trip>>???????????? RE: engine problems need some advice - newguy - 07-16-2014 (07-16-2014, 04:14 AM)fixkick Wrote: a bit>? 1oz, 1/2 a quart.? yes after it is warmed up it has a lingering smoke coming out of the tail pipe and ill get to the dip stick test. I thing about 1oz |
