Remove the locking washers from the wheel studs - Printable Version +- Car Repair Forum (https://fixkick.com/forum) +-- Forum: Suzuki (https://fixkick.com/forum/forum-suzuki) +--- Forum: Sidekick/Tracker (https://fixkick.com/forum/forum-sidekick-tracker) +--- Thread: Remove the locking washers from the wheel studs (/thread-remove-the-locking-washers-from-the-wheel-studs) |
Remove the locking washers from the wheel studs - Vitalie - 07-08-2014 Hi there I planed to work on my brakes the other day, and when I got to rear brakes, after removing the wheels , there are so called "locking washers" on the studs. How do you remove these? I kinda tried to force them a bit, but they do damage the studs. So put the wheels back till i figure it out. I am sure it something simple. Thanks RE: Remove the locking washers from the wheel studs - fixkick - 07-08-2014 (07-08-2014, 08:29 AM)Vitalie Wrote: Hi there sure, i bet they brakes are still day one original. amazing huh. those are stud , drum keepers, it keep the drums from falling off. (92 and newer) this I think are just for easy to manufacting of car, keeps drums from falling off , on assembly lines. they only go on, but break coming off, (1/2 or more the time) i throw them away., the wheel keeps the drums fast. the are flat spring clips. large version of the clips that hold on body emblems. 1991 , has center bolts yours does not.
RE: Remove the locking washers from the wheel studs - Vitalie - 07-08-2014 Hey That's is what I was thinking. I will try to pry them with a screwdriver and pliers. in this picture you have only 4 studs, as far as know they are 5. is this an older model? Thanks again. RE: Remove the locking washers from the wheel studs - fixkick - 07-09-2014 ops sorry , that is 91, those are drum studs, sorry, but its the same deal. my 04 the hole in center is larger on the 04 but is same deal. btw , the parts catalog does not not show the clips. im sure its for factory convenience. RE: Remove the locking washers from the wheel studs - gorkyb - 07-09-2014 My Jeep JK had the same, I just used cutting pliers, cut them in a couple of spots and removed them. RE: Remove the locking washers from the wheel studs - fixkick - 07-09-2014 it about the only part on the car that is , not needed, these cars are spartan |
