Alternator Bolt? - Printable Version +- Car Repair Forum (https://fixkick.com/forum) +-- Forum: Suzuki (https://fixkick.com/forum/forum-suzuki) +--- Forum: Sidekick/Tracker (https://fixkick.com/forum/forum-sidekick-tracker) +--- Thread: Alternator Bolt? (/thread-alternator-bolt) |
Alternator Bolt? - Vitalie - 04-11-2014 Hi there. I got one more problem. I was checking my accessory belts as they were e squeaking at start up and I found that my Alternator bottom long bolt snap right the end where the nut tightens. Now is basically just like that. Autozone sold me some c**p no surprise it dose not fit. All the dealers I called it is discontinued. Can you help me buy it from suzuki I tried but could not find it. thanks a lot RE: Alternator Bolt? - fixkick - 04-11-2014 sure, what part exactly the alt, bottom long bolt. pivot bolt, sure. there are 2, both at bottom, one front and one rear. and both are same size. m8? (you can buy better bolts at many good stores) the mount is threaded. the orig. stock bolt p/n is.. 01550-08253 and was superseded to 015500825A https://monsterfactoryparts.com/parts/1995/Suzuki/Sidekick/index.cfm?siteid=217481 RE: Alternator Bolt? - Vitalie - 04-11-2014 ok I see. Well, mine instead of the 2 #5 bolts from the picture above I had only one long one that went all the way through. Probably previous repair creative touch. Now it make sense why you saying 2 bolts as I was a bit confused. thanks RE: Alternator Bolt? - fixkick - 04-11-2014 he stripped out the mount. so that was his fix. ill look up the cost of the mount. 40bucks https://monsterfactoryparts.com/parts/1995/Suzuki/Sidekick/index.cfm?siteid=217481 17911-71C02 RE: Alternator Bolt? - Vitalie - 04-12-2014 I just put 2 bolts and hope to hold it. Thanks for help realizing the modification. RE: Alternator Bolt? - fixkick - 04-12-2014 yes, if the treads are stripped, try 2 bolts and 2 nuts. only hard part is reaching all 4 points at once to tighten them. good luck to you. |
