rod through block - Printable Version +- Car Repair Forum (https://fixkick.com/forum) +-- Forum: Suzuki (https://fixkick.com/forum/forum-suzuki) +--- Forum: Sidekick/Tracker (https://fixkick.com/forum/forum-sidekick-tracker) +--- Thread: rod through block (/thread-rod-through-block) |
rod through block - hoffy30 - 03-28-2014 Hi I was towing tracker with transmision in second and transfercase in neutral l thought.Turned out it was in 4high.Rod went through block.So I left vehicle in Mexico .What potentuanly would be wrong with motor.Do you think head would be ok AND DO YOU THINK trany and transfercase would be ok.Thank you friend of Kevins Don RE: rod through block - fixkick - 03-28-2014 only a dismantle can tell. |
