1995 geo tracker 2wd - Printable Version +- Car Repair Forum (https://fixkick.com/forum) +-- Forum: Suzuki (https://fixkick.com/forum/forum-suzuki) +--- Forum: Sidekick/Tracker (https://fixkick.com/forum/forum-sidekick-tracker) +--- Thread: 1995 geo tracker 2wd (/thread-1995-geo-tracker-2wd) |
1995 geo tracker 2wd - tsbirdone - 03-17-2014 turn signals will work some times sometimes they wont sometimes they work will quit in the middle of a cycle any ideas what might be the problem ie flasher,ground problem any help appreciated thanks RE: 1995 geo tracker 2wd - fixkick - 03-17-2014 all those. sure. but do the hazard switch also fail. in fact cycle the hazard switch say 5 times, they never get used, so get bad contacts and act up.. turns sigs dead both sides. and when fail, are dead, not stuck on? (03-17-2014, 11:40 AM)tsbirdone Wrote: turn signals will work some times sometimes they wont sometimes they work will quit in the middle of a cycle any ideas what might be the problem ie flasher,ground problem any help appreciated thanks |
