Valve spring compressor for G16B 16v - Printable Version +- Car Repair Forum (https://fixkick.com/forum) +-- Forum: Suzuki (https://fixkick.com/forum/forum-suzuki) +--- Forum: Sidekick/Tracker (https://fixkick.com/forum/forum-sidekick-tracker) +--- Thread: Valve spring compressor for G16B 16v (/thread-valve-spring-compressor-for-g16b-16v) |
Valve spring compressor for G16B 16v - rupal - 03-02-2014 Hi, Can someone point me in the right direction as to what type valve spring compressor to use on a G16B 16v engine. I have bought two different types & none of the fit\work with the design of the head... Cheers RE: Valve spring compressor for G16B 16v - gorkyb - 03-02-2014 Head off the car right? If so, I used on mine: http://www.mechanicstoolsandbits.com/otc-tools-large-valve-spring-compressor-38x5-otc4572-p-1731.html?gclid=CJH_l9zT8rwCFS9p7AodPVkAbw RE: Valve spring compressor for G16B 16v - rupal - 03-02-2014 (03-02-2014, 11:03 AM)gorkyb Wrote: Head off the car right? If so, I used on mine: http://www.mechanicstoolsandbits.com/otc-tools-large-valve-spring-compressor-38x5-otc4572-p-1731.html?gclid=CJH_l9zT8rwCFS9p7AodPVkAbw No, i'm replacing the seals with the head on. RE: Valve spring compressor for G16B 16v - fixkick - 03-02-2014 page 30 and 66, (pdf page) http://www.acksfaq.com/96-FSM-v1-6A-pdf.htm j8062 with J37979 adapter. many time a generic tool and a home made adapter. insane expensive tool $300.... http://www.toolsource.com/valve-spring-compressor-universal-p-108224.html http://www.toolsource.com/advanced_search_result.php?search=1&query=J37979&x=14&y=9 i used copper plumbing couplings to make and adapter. with a window cut in the side, to tickle out valve keepers.. i also used it on a motorcycle head. |
