91 tracker 8v PS pump no work when cold - Printable Version +- Car Repair Forum (https://fixkick.com/forum) +-- Forum: Suzuki (https://fixkick.com/forum/forum-suzuki) +--- Forum: Sidekick/Tracker (https://fixkick.com/forum/forum-sidekick-tracker) +--- Thread: 91 tracker 8v PS pump no work when cold (/thread-91-tracker-8v-ps-pump-no-work-when-cold) |
91 tracker 8v PS pump no work when cold - barnbiketom - 02-19-2014 the power steering no workie when cold.. it whines just like it is empty, but IS NOT. it is right up to the max line. no power steering until a minute or warm up then all is good. I removed the filter that sits inside the reservoir, cleaned it and re-installed it. maybe the previous owner put something different in? i may just flush it all out and put in?? what??? synthetic?? i jist thought of something.. wonder if a ps hose is bad , inside, restricted?? RE: 91 tracker 8v PS pump no work when cold - fixkick - 02-19-2014 air in the system.? all ATF is syn, so dont pay extra for that. (syn in , usa only means groupIII base oil, ) do use fresh dexron III or higher. no loose belt. get air out by front wheels off ground, engine idling. and spin steering wheel full left and right like a wild man. in hard nut cases, a cap with vacuum fitting , and hand vac tool , cures them all. i hope your hoses are good. that would be not fun. pg 9-21 (pdf 125) http://www.fixkick.com/All-Pdfs/Other-Manuals/operators_guide-95/95sidekick_owner_manual.pdf RE: 91 tracker 8v PS pump no work when cold - barnbiketom - 02-19-2014 the fluid in it now is clear.. maybe someone put ps fluid in it, but i think i'll flush it all out and stat with dextron.. RE: 91 tracker 8v PS pump no work when cold - fixkick - 02-19-2014 that's not dexton/ must be wrong, red official spec; 1136 DEXRON RE: 91 tracker 8v PS pump no work when cold - barnbiketom - 02-24-2014 OK I removed the reservoir and placed a funnel into the inlet hose. extended the outlet hose down to the ground into a 5 gallon bucket. wife started little tracker and spun steering to and fro left to right lock. ( thank you Cindy) I poured 4 quarts of dextron into funnel slowly and purged entire system of WHO KNOWS WHAT?? MOTOR OIL??? WTF Now in morning I have POWER STEERING NO GROAN AND MOAN..... all is good.. and steers better than it ever did hahahahha TODAY I unlocked the front hubs... spring is coming!! Now if I can just get the snow tires off and summer will be here??? ![]()
RE: 91 tracker 8v PS pump no work when cold - fixkick - 02-25-2014 might be the work of kwicklube joints. im sorry someone did this to your car, wow, it works like new. so glad for you. RE: 91 tracker 8v PS pump no work when cold - barnbiketom - 02-25-2014 thanks. it worked good until the weather got cold.. tomorrow morning will be 11 F so I will try it!! |
