Lifts - Printable Version +- Car Repair Forum (https://fixkick.com/forum) +-- Forum: Suzuki (https://fixkick.com/forum/forum-suzuki) +--- Forum: Sidekick/Tracker (https://fixkick.com/forum/forum-sidekick-tracker) +--- Thread: Lifts (/thread-lifts) |
Lifts - stickerbuoy - 01-18-2014 Another question. Do you have any experience with lifting sidekicks? I have a '96 4-door Automatic Sidekick. I picked up a 1.9TD from a '96 Jetta, and I was hoping to make the swap using an Acme kit. It will be a daily driver, with occasional off-roading and towing. The diff is 5.125:1 right now, but I do have a 2-door '95 16V with 4.3:1. Even if I was able to swap in the 4.3:1, I calculated that I would still need 32"-33" tires to get close to the stock gearing of the jetta. From what I've read the Jetta had a 3.157:1 diff. If I could get something between that and my 4.3:1 then I could hopefully get away with a little less body lift and smaller tires. Otherwise I don't see how I could go with anything less than 6" (3" suspension/3" body) and 33's unless I wanted to be a slug on the highway. The sidekicks seem to have a fairly high center of gravity already too. Have you heard of any gears available between the 3.157:1 and 4.3:1? RE: Lifts - fixkick - 01-18-2014 the axles match the tranny, (and rpm of gas engine (fast on this small 1.6)) http://www.fixkick.com/sensors/speedo/unsafe-at-any-speed.html#ratios here is the world wide list jack ups can be easy or hard. higher harder. U-joint issues? any linkage from body to frame parts and drive line father below, can be a problem. a compilation http://www.fixkick.com/specs/all_axle_ratios_list.txt what cool project, a 1.9TD kick... RE: Lifts - stickerbuoy - 01-18-2014 I've heard of people using the front diff. gears from a sidekick in a samurai. Are the gears in the front and rear different sizes? Would sammy R&P's work in a sidekick? RE: Lifts - fixkick - 01-18-2014 same or bad happens. they are linked with a ratio of 1:1 front to rear., of not 1:1, skid city yes many sammi are just bodies, all parts bolted on, non sammi. fun to watch.. love it. RE: Lifts - stickerbuoy - 01-18-2014 Here's an example of a few threads that I've come across that say only the front diff gears in a sidekick will work in a samurai: http://www.zukikrawlers.com/showthread.php?t=41552 http://www.pirate4x4.com/forum/suzuki/601123-gear-swap-tech.html RE: Lifts - fixkick - 01-18-2014 oops i missed the gear swap question gear swaps not = to carriers. sorry |
