turn signal/ hazard Flasher - Printable Version +- Car Repair Forum (https://fixkick.com/forum) +-- Forum: Suzuki (https://fixkick.com/forum/forum-suzuki) +--- Forum: Sidekick/Tracker (https://fixkick.com/forum/forum-sidekick-tracker) +--- Thread: turn signal/ hazard Flasher (/thread-turn-signal-hazard-flasher) |
turn signal/ hazard Flasher - 98TrackerMan - 04-14-2024 Hello All, Long time since I posted. Here's the little problem. Where is the Flasher located? under the dash or engine compartment? and this is the part number i found online --Genuine GM Hazard Warning Flasher "30026596" thanks in advance REGARDS, 98TrackerMan RE: turn signal/ hazard Flasher - fixkick - 04-17-2024 best i can tell here. 96 up this is new spot. ID 23 g200 ground to it must be good cycle the HAZ switch are HAZ dead too.? or cylcing the old crusty HAZ switch now self cleans its contacts and blinkers work ,turns and haz both,see this happen too many times http://fixkick.com/power-elect/Relays/98-lays.JPG RE: turn signal/ hazard Flasher - 98TrackerMan - 04-18-2024 THANKS FixKick for taking the time & diagram for reply hazards are ok-- turn signals on dash were blinking fast- Now that i am armed with info I'll be checking all around-with diagram in hand-- everything was original- never had to service this since 1998- I did see bulb out in rear out- Success! Regards 98TrackerMan RE: turn signal/ hazard Flasher - fixkick - 05-03-2024 yes the flasher box , does odd thing if 1 lamp is open or shorted. it does that on purpose to tell the owner , it has a problem. SOLVED , and Happy trails to you. |
